Poisson/Arago's spot in water?
  • Thread starter Thread starter nonequilibrium
    Water
Poisson's spot, a phenomenon related to the wave nature of light, raises questions about its equivalent in water waves, particularly surface gravity waves. The discussion highlights the differences between electromagnetic waves and water waves, such as dispersion relations and viscosity effects. While Lamb's work on sound waves does not indicate a similar effect, the concept of observing an Arago-like spot in water waves remains intriguing. The idea of conducting an undergraduate project to explore this 2D equivalent, akin to an inverted single slit experiment, is proposed. This exploration could yield interesting insights into wave behavior in different mediums.
nonequilibrium
Hello,
So Poisson's spot is a (peculiar) effect of light due to its wave nature (it's the bright point one would see in the middle of the shadow of a perfectly round coin).
So I was wondering, has Arago's spot been observed for water waves too? For example in a 2D equivalent, i.e. for surface gravity waves.
Interesting... it seems that there could be, but water waves are slightly different than electromagnetic waves- the dispersion relation for example, and dissipation due to viscosity. Lamb only treats sound waves diffracted though a aperture that is smaller than the wavelength, and those results do not indicate any phenomenon similar to the spot of Arago.
Seems like a good undergraduate project, actually!
The 2D equivalent would be like an inverted single slit experiment - should be observable.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
