Current & Voltage: Understanding Resistance Limits
  • Thread starter Thread starter sneha_28
    Current Voltage
A resistor limits current, but in a series circuit with a voltage source, the current remains constant throughout due to Ohm's law, which states that current is directly proportional to voltage and inversely proportional to resistance. The discussion highlights a common misunderstanding regarding current flow in series circuits, emphasizing that while resistance can limit current, it does not change the current value at different points in the circuit. The water analogy is used to illustrate that, similar to flow rate in a pipe, the current remains the same despite passing through resistors. The key takeaway is that in a series circuit, the same amount of current flows through all components, regardless of the resistance values. Understanding these principles clarifies the behavior of current in electrical circuits.
sneha_28
I have a basic doubt regarding concepts of current. we know that a resistor is a current limiting device. But when it is connected in series with a voltage source,current remains the same.
Why doesn't the current change even after passing through a series of current limiting resistors? what am i missing out here?
What makes you think that the current doesn't change when the resistance changes? What's your understanding of Ohm's law?
The way the question was worded implies adding resistance, but I think the question was why isn't the current different in different parts of the circuit.
Water analogy: why isn't flow rate lower after an obstruction in a pipe?
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
