Why Does Mathematical Induction Prove Formulas True for All Positive Integers?
Mathematical induction proves formulas true for all positive integers by establishing a base case and an inductive step. The base case confirms the formula is true for n=1. The inductive step shows that if the formula holds for an arbitrary positive integer k, it must also hold for k+1. This creates a chain reaction, confirming the formula for all subsequent integers. Thus, once the base case and inductive step are validated, the formula is proven true for all positive integers.
andrewkg
Hello I'm learning about proofs and in my book there's a sect. On mathematical induction. And I'm trying understand why this makes it true for all values.
1+3+5...2n-1=n^2
Suppose that the formula is known to be true for n=1, and suppose that as a result of assuming that it is true for n=k, where k is an arbitrary positive integer, we can prove that it is also true for n=k+1.
Then the formula is true for all k.
Why does this addition of 1 make it true for all k?
Mathematics news on Phys.org
You know it's true for n=1 and you know that for every n where it's true, it's also true for n+1. Since you proved it for 1, this implies it's true for 1+1 = 2. Now, since you know it's true for 2, it must be true for 2+1 = 3. Now since you know it's true for 3, it's also true for 3+1 = 4. And so on, so it's true for every positive integer.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
