How Does Two Car Drafting Reduce Air Resistance for Faster Speeds?
  • Thread starter Thread starter Ranger Mike
    Car Cars Drafting
Two-car drafting significantly reduces air resistance, enhancing speed due to the aerodynamic effects created by the leading car. The leading car pushes aside a large curtain of air, creating a low-pressure wake that decreases drag on the trailing car. This allows the second car to follow closely, further minimizing the high-pressure air hitting the lead car's spoiler. Consequently, both cars experience reduced drag, enabling them to achieve faster speeds than a single car would alone. Understanding these dynamics is crucial for optimizing racing strategies.
Ranger Mike
two car cars "drafting"
As posted by Hootenanny on another topic..he kindly replied "the car also experience fluid resistance or drag. For large objects traveling at high speeds the magnitude of the drag force is considered to be proportional to the square of the velocity of the car."
Is the reason two car cars " drafting" move faster than one car due to the massive curtain of air being pushed aside by the two cars? The two cars push aside the curtain of air and create a slight vacuum or low perssure area immediately behind the trail car. The air curtain closing behind the pair, " pushing the two cars with more force" than one car cutting through the air?
or did I miss something?
Here's a good description:
The low-pressure wake behind a group's leading car reduces the aerodynamic resistance on the front of the trailing car, allowing the second car to pull closer. As the second car nears the first, it pushes high-pressure air forward so less fast-moving air hits the lead car's spoiler. The result is less drag for both cars, allowing faster speeds. [2]
http://en.wikipedia.org/wiki/Drafting_(racing)
wish I had access to this site years ago..it is gold mine of valuable insight and information
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
