What is Hartridge Smoke Unit (HSU) ? for Diesel engine emission
The Hartridge Smoke Unit (HSU) measures smoke opacity in diesel emissions, with values ranging from 0 (perfectly clear) to 100 (completely opaque). Visual representations of smoke opacity are not reliable due to varying light conditions affecting perception. The relationship between HSU and the Filter Smoke Number (FSN) is of interest, as both systems provide different metrics for assessing emissions. Understanding these values is crucial for evaluating the filtration power of particulate removal systems. Accurate interpretation of HSU readings is essential for determining the cleanliness or smokiness of diesel emissions.
Su Solberg
I am working of the Diesel Emission Project, however i have some problem in evaluating the filtraion power of the Particulate Remover Unit. The following is my question:
Could anyone can provide some picture of different level of HSU so that I can understand the visual scenario of different value (e.g. 25, 50, 100, 150)?
Thank you very much for your kind help.
Pictures won't give you a good idea of smoke opacity, which is what you're interested in. A value of 0 indicates perfect transmission, or zero opacity. A value of 100 indicates total absorption, or complete opacity. This is referenced (in the case of HSU) to a transmission length of 430mm, at 100°C and atmospheric pressure. Values in between are not linear with respect to actual light absorption.
Thank you very much for your reply.
However, I would like to ask how to verify the meaning that the emission is clean or smoky in terms of HSU?
Could you provide some picture??
Thank you very much for your help.
0 is invisible, 100 is a thick, dense smoke. Then you have everything else in between. As I stated, pictures are pretty useless, since this isn't a subjective measure, and the same smoke level can look good/bad depending on light conditions, background colour, and dilution.
Pretty smoky:
Pretty clean:
Anyone who can tell me the corelation between Hartridge Smoke Unit (HSU) and FILTER SMOKE NUMBER(FSN) as I have the two systems giving one in HSU and the other in FSN.I would like to compare the result given by the two SYSTEM
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
