Find q in F = qVe + (Pe - Pa) * Ae with this simple formula
  • Thread starter Thread starter .:Endeavour:.
    Arithmetic Formula
To isolate q in the equation F = qVe + (Pe - Pa) * Ae, the correct approach involves moving the entire term (Pe - Pa)Ae to the opposite side of the equation. This results in F - (Pe - Pa)Ae = qVe. Dividing both sides by Ve gives the correct formula q = (F - (Pe - Pa)Ae) / Ve. The confusion arose from misapplying the order of operations, particularly regarding the multiplication and division of terms. Clarification confirmed that Ae should multiply (Pe - Pa) rather than divide F.
.:Endeavour:.
I have this formula: F = qVe + (Pe - Pa) * Ae; I want to get q by its self. This what I did to get q by its self.
\frac{F - (P_e - P_a)}{(A_e)} = \frac{(V_e * q)(A_e)}{(A_e)}
[( F - (Pe - Pa)) ÷ Ae] ÷ Ve = q
This is how I got q by itself in order to solve for q. I'm not sure if its correct, so please look over it to see if its correct. Thank you for your time.
Mathematics news on Phys.org
It's wrong. When you move the (Pe-Pa)Ae term over to the side with F, you lost the Ae and multiplied Veq by Ae instead.
Office_Shredder said:
...you lost the Ae and multiplied Veq by Ae instead.
I don't get what you are saying by loosing Ae from (Pe - Pa). I get wat you are saying after the and part of the sentence. Can you change the place of Ae because of order of operations, you will have to multiply first before you can add: + Ae * (Pe - Pa)?
I think what you did, correct me if I'm wrong, is subtract (Pe-Pa) from both sides and then divide everything by Ae.
The problem with this is that subtracting from the right hand side doesn't eliminate the (Pe-Pa) because it has an Ae attached to it. What Office_Shredder is saying is you have to move the entire term, Ae(Pe-P), over to the other side:
F=qV_{e}+(P_{e}-P_{a})A_{e}
Subtract (P_{e}-P_{a})A_{e} from both sides:
F-(P_{e}-P_{a})A_{e}=qV_{e}+(P_{e}-P_{a})A_{e}-(P_{e}-P_{a})A_{e}
\frac{F-(P_{e}-P_{a})A_{e}}{V_{e}}=q
To make explicit what you did:
F-(P_{e}-P_{a})=qV_{e}+(P_{e}-P_{a})A_{e}-(P_{e}-P_{a})
And you see the terms don't drop out on the right hand side. Hope this clarifies.
Ok, yes it does clarify. Ae is meant to multiply with (Pe - Pa) not to divide F - (Pe - Pa), which is not dividing but multiplying. Thank you for your help.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
