Comparing Two Circuits: Can We Say Low Pass Filter?
The discussion focuses on the comparison of two circuits, one stimulated by a current source and the other by a voltage source, both yielding the same output voltage. It confirms that the first circuit can be classified as a low pass filter, referencing the concept of source transformation, which allows for converting a voltage source with a series resistor into a current source in parallel with the same resistance. The participants express curiosity about the practical applications of source transformation, particularly in cascading filters. They note that while RC circuits are straightforward, combining multiple filters may require different configurations. Ultimately, the conversation highlights the theoretical understanding of filters and their practical implications in circuit design.
somasimple
Hi all,
Here is a picture of two circuits.
The one at the left is stimulated with a current source and the other with a voltage source.
They give the same results V(1) = V(2).
Is it possible to say that the primer is a low pass filter?
Yes. Somewhere buried away in your textbook is something call source transformation. If you have a voltage source with a series resistor, you can transform it to a current source in parallel with the same resistance. The current source is simply the original voltage source divided by the resistor.
Thanks Corneo,
I wasn't aware of such circuit but find a good description in this http://books.google.com/books?id=sx...r=&ei=v5_AScGeEp-8zgTIwOH3Bw&hl=fr#PPA118,M1"
What is its interest by the way?
Normally the simple nature of RC cells give us an entry point and an exit one. This permits a cascading with two or more filters.
In this configuration the applied source is modified by the filter but I see no way to assemble multiple filters?
What good is source transformation? Honestly I don't know. I have never ever had to use it at in career so far (2 years). If you want to cascade the filter, you could just place the next filter in parallel to the resistor and cap, the currents sources would add. The resistors would combine in parallel; the caps would add in value.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
