Work and Potential/Kinetic Energy (spring problem)
  • Thread starter Thread starter stevebrstlct
    Energy Work
The discussion revolves around a physics problem involving a ball dropped onto a vertical spring, requiring the calculation of the ball's speed when the spring is compressed and the maximum compression distance. The conservation of energy principle is key, as it combines gravitational potential energy and spring potential energy. The participant initially struggled with the acceleration due to gravity affecting the ball's motion but clarified their understanding by calculating the potential energy changes. They confirmed that the remaining energy after spring compression translates into kinetic energy. The conversation concludes with a clearer grasp of the energy transformations involved in the problem.
stevebrstlct
A)
A ball with a mass of .360kg is dropped from a height of 1.20 meters above the top of a fixed vertical spring, whose force constant is 350 N/m. What is the speed of the ball when the spring has been compressed 5.0cm?
(Ignore the mass of the spring; also, notice that this problem contains both forms of potential energy (gravitational and spring pot'l En.)
B)
What is the maximum distance the spring is compressed by the ball?
Work=F\cdotD
PE:
U=1/2K(xf-xi)2
\DeltaU=mg\cdot\DeltaY
Ki+Ui=Kf+Uf
m=.360 Kg
H=1.2m
\DeltaX=5.0 cm
K=350 Nm
We did a problem similar to this on a frictionless horizontal plane. We used the conservation of energy to solve it. In the picture we drew we found where the Pot. and Kin. energies were zero which left the equation with only one unknown left. In that problem there was constant velocity but in the problem I just posted we have an acceleration of mg down which leaves me confused on what the right way to solve this is. I also know for part B the velocity will be 0.
Welcome to PF.
Figure your changes in potential energy.
m*g*h = .36*9.8*(1.2 + .5)
Now how much potential energy is in the spring?
1/2*k*x2
Whatever is left over then must be kinetic energy right?
Wow that makes much more sense now, thanks alot!
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
