Is High Voltage DC Current Dangerous?
High voltage DC current can indeed cause electric shock if it exceeds the body's resistance, contrary to the belief that DC is safe. While low frequency AC is more easily felt, high voltage levels of either AC or DC can be jolting and painful. High frequency AC may not be felt immediately but can cause severe burns, raising concerns about its danger. The skin effect influences how AC and DC currents interact with the body, with DC potentially being more hazardous due to its ability to penetrate deeper. It is crucial to prioritize electrical safety and seek proper guidance to avoid serious harm.
samieee
I have heard that 'we don't get shock from dc current because it is constant but we get shock from ac current because it is alternating'.Is that true? If it is HIGH VOLTAGE DC CURRENT THEN?
If the amount of current passing through our body breaks the resistance of it then what we feel is called electric shock isn't it? then I think we must get shock from dc current if the amount is considerably high (that means breaks our resistance)
Is that true?
Most definitely not true.
Whoever told you this may be referring to a classroom demonstration where someone is invited to touch a single high voltage terminal (for example in a Van der Graff generator), whilst being carefully insulated from the rest of the planet.
This can safely be done by most people.
However as a general rule it is a very bad idea to touch electric terminals.
When the voltages / currents are low, low frequency AC is more discernible. However, when you go up in voltage, both become jolting and painful.
High frequency AC (i.e. > 1MHz) gets to where you don't notice shock, but you can get severe penetrating burns before you notice something's happening.
though there is debate which one is more dangerous, I think dc is more because ac current will flow through the skin rather than heart due to skin effect
The skin effect has nothing whatsoever to do with human (or animal) skin.
Sam, please get some proper advice about electrical safety before real harm is done.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
