How Do You Determine the Algebraic Multiplicity of an Eigenvalue?
  • Thread starter Thread starter dlevanchuk
    multiplicity
The discussion focuses on determining the algebraic multiplicity of the eigenvalue λ = 2 for the matrix A with the characteristic polynomial p(t) = (t + 2)(t - 2)³. The algebraic multiplicity is defined as the exponent of the factor corresponding to the eigenvalue in the characteristic polynomial. In this case, since (t - 2) appears with an exponent of 3, the algebraic multiplicity of λ = 2 is conclusively 3.
  • Understanding of eigenvalues and eigenvectors
  • Familiarity with characteristic polynomials
  • Knowledge of algebraic and geometric multiplicities
  • Basic linear algebra concepts
  • Study the properties of characteristic polynomials in linear algebra
  • Learn how to compute eigenvalues and eigenvectors using matrix diagonalization
  • Explore the relationship between algebraic and geometric multiplicities
  • Investigate applications of eigenvalues in systems of differential equations
Students of linear algebra, mathematicians, and anyone involved in advanced mathematical computations requiring a solid understanding of eigenvalues and their properties.
dlevanchuk
I have a matrix A [1 -1 -1 -1; -1 1 -1 -1; -1 -1 1 -1; -1 -1 -1 1], its characteristic polynomial p(t) = (t + 2)(t-2)3, and given value of lambda = 2. I need to find basis for eigenspace, and determine algebraic and geometric multiplicities of labmda.
I did find the basis, and geometric multiplicity (the dimension of eigenspace).. but I can't figure out how to figure out algebraic multiplicity! I know the correct answer is 3, but why? i was trying to find simple explanation of alg. mult. on google, but the answer come up waay too tangled up for me to understand :-S
EDIT: Is it because the characteristic polynomial is p(t) = (t + 2)(t-2)3 and since my lambda = 2, i need to take (t-2)3 (which is t-2=0 => t=2), and the power is the value of algebraic mult...? am I on the right track?
You're on the right track. The multiplicity is basically how many "copies" of each eigenvalue exist. If each eigenvalue is unique, the multiplicity is 1. Since you have (t-2)^3, the eigenvalue of 2 is repeated three times, so the multiplicity is three, as you said.
  • · Replies 24 ·
  • · Replies 19 ·
