S vs P Polarization: Explaining Ex Component
  • Thread starter Thread starter geo_alchemist
    Polarization
S-polarized light has electric field components only parallel to the surface, represented as Ei=(0, Ey, 0), while P-polarized light includes an Ex component, as well as Ez, since its electric field lies in the plane of incidence. The essential difference between S and P polarization is the orientation of the electric field relative to the plane of incidence. Clarification was sought regarding the Ex component in P-polarization, which was resolved through visual aids. The discussion highlights the importance of understanding these components in the context of light propagation and polarization. Overall, the distinction between S and P polarization is crucial for applications in optics.
geo_alchemist
Let us imagine a surface, with X and Y axes on it and Z axis normal to it.
well, the theory, (in my particular case, some article) says that S polarized light, propagating along the x-directioin possesses only electric field components, Ei, parallel to the surface (||y-direction), i.e. transversal electric waves have Ei=(0, Ey, 0), while P-polarized light has Ei=(Ex, 0, Ez).
The question:
I understand that S-polarized light, propagating along x-direction has only electric field components, Ei, parallel to the surface. Ei=(0, Ey, 0), since in case of s-polarization E is perpendicular to plane of incidence.
Also I understand that P-polarized light, propagating in the same x-direction has Ez component, since in case of P-polarization E is in the plane of incidence.
what I do not understand is, why p-polarized light has Ex component.
Science news on Phys.org
Do you see the essential difference between s- and p- polarization? It's not the (x,y,z) components per se, it's whether or not the electric field is in the plane of incidence.
Essential difference I see perfectly. what I need is to describe this difference in terms of Ex, Ey and Ez.
Anyway, now I understand it, thanks for picture ;)
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
13K
