Revolutionize Energy Storage: Utilizing Flywheels for Efficient Power Generation
The discussion focuses on utilizing flywheels for energy storage, specifically a 10 kg steel flywheel charged to 7,000 RPM to store 268 KJ of energy. The user seeks to charge the flywheel using a Honda GX50 engine and discharge it to power a light three-wheeled vehicle. Key questions include calculating the charging time without intermediate devices and determining the discharge time and characteristics. Responses suggest that the charging time depends on the energy supplier and utilization dynamics, while the discharge can be analyzed similarly by treating the flywheel as a motor. The conversation emphasizes the potential of flywheel energy storage for practical applications.
grey
I have an idea pertaining to energy storage in flywheels, something like they do in the KERS, and need assistance here...
Ok, my idea involves using a flywheel of around 10 kg (steel) with I~1 kg.m^2, to be charged to an RPM of around 7,000 RPM.
This allows E = 0.5 x 1 x (7000x2x pi /60)^2 = 268 KJ of energy to be stored.
I want to charge it with a small engine (something like a Honda GX50) which, according to the charts will give max torque of 3 Nm at 4000 rpm and max power of 1.6 kW at 7000 rpm (approx).
I want to discharge it to run a light vehicle (170 kg including driver) such that the discharge takes place at one wheel only (a three wheeler). I want discharge in pulses.
Now, the questions:
1. How do I calculate the time it takes to charge the flywheel to 7000 RPM? Can I do it without using some intermediate device like a CVT or motor/generator?
2. How do I calculate the discharge time (and characteristics)?
Thanks in advance.
I think flywheel energy storage is a really interesting topic, I would love to see more practical uses of them! If you end up making something, please post it.
Now, the questions:
Thanks in advance.
Hi-
1. The time it takes for increase the kinetic energy of the flywheel mainly (but not finally) depends on the characteristics of the energy supplier (your GSX50) and utilizer (in a direct coupling). Write down the energy balance and you will get the dynamics (and then the time). But direct coupling seems to me a not real event..
2. For the discharge time you can use the same approach, this time the flywheel is the motor.
M
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'What type of toilet do I have?'
I was enrolled in an online plumbing course at Stratford University. My plumbing textbook lists four types of residential toilets: 1# upflush toilets 2# pressure assisted toilets 3# gravity-fed, rim jet toilets and 4# gravity-fed, siphon-jet toilets. I know my toilet is not an upflush toilet because my toilet is not below the sewage line, and my toilet does not have a grinder and a pump next to it to propel waste upwards. I am about 99% sure that my toilet is not a pressure assisted...
After over 25 years of engineering, designing and analyzing bolted joints, I just learned this little fact. According to ASME B1.2, Gages and Gaging for Unified Inch Screw Threads: "The no-go gage should not pass over more than three complete turns when inserted into the internal thread of the product. " 3 turns seems like way to much. I have some really critical nuts that are of standard geometry (5/8"-11 UNC 3B) and have about 4.5 threads when you account for the chamfers on either...
