Power Amplifier output to 3 Phase Motor
Power amplifiers output power to 3 phase motors by distributing current across the phases, and in this case, a peak output of 40A refers to the total output across all three phases, not per phase. When using a relay to interrupt motor current, it is crucial to size the relay appropriately to handle the total current without compromising safety. The discussion suggests that using a single contact for each phase may allow for a less expensive relay, but caution is advised. Additionally, using a variable frequency drive (VFD) can simplify the setup, as a 3 phase breaker before the VFD may suffice for interrupting power. Proper specifications of the VFD are essential for determining the correct relay size and ensuring safe operation.
smitty1701
Hello Everyone,
I have a question about how power amplifiers output their power to 3 phase motors. I am using a copley xtl power amplifier to power a 3 phase motor, i want to use a relay to interrupt that motor current but I am not sure how to size it. If the peak output of the amplifier is 40A does that mean each phase of the motor can get 40A or does that mean the total output over the three phases is 40A? I am trying to get away with attaching each phase of the motor to one contact on the relay so i can hopefully use a cheaper relay without degrading safety. The power amplifier uses PWM to send a sine wave to the 3 phase motor.
Thanks for any help
Normally, you would use a starter circuit like this:
But if you have a http://en.wikipedia.org/wiki/Variable-frequency_drive" , just a 3 phase breaker (before the VFD) to break the supply is all that's needed.
As far as the rating goes, do you have the specifications of the VFD you're using?
Welcome to PF
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Thread 'Beauty of old electrical and measuring things, etc.'
Even as a kid, I saw beauty in old devices. That made me want to understand how they worked. I had lots of old things that I keep and now reviving. Old things need to work to see the beauty. Here's what I've done so far. Two views of the gadgets shelves and my small work space: Here's a close up look at the meters, gauges and other measuring things: This is what I think of as surface-mount electrical components and wiring. The components are very old and shows how...
