Angle of Vectors with X, Y, and Z Axis
  • Thread starter Thread starter lmf22
    Angle Vectors
To find the angle a vector makes with the X, Y, or Z axis, use the dot product formula with the unit vectors of each axis. For the vector V = 24i + 12j - 20k, the angles can be calculated using the inverse cosine of the dot product of V with the unit vectors. A calculator can expedite this process for accuracy and efficiency. The discussion highlights the importance of understanding vector components and their relationships to the axes. Proper use of mathematical tools simplifies finding these angles.
lmf22
vectors and angle...
How can I find the angle that a vector makes with the X, Y, or Z axis?
Example: V=24i + 12j - 20k. What angle does this vector make with x, y, and z axis?
How do you find the angle between two vectors in general?
Do i use inverse cosine?
Ox : (1,0,0)
Oy : (0,1,0)
Oz : (0,0,1)
V : (24,12,-20)
"Do i use inverse cosine?"
If you don't, you should use a calculator to help you find the angle, its faster. I do it all the time.
Thank you. I got it now.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
