Why is there never any electric field in a hollow conductor?
In a hollow conductor, the electric field inside is zero due to induced charges on the surface that effectively screen the field. This means that while there may be field lines approaching the surface, they do not penetrate the conductor itself, resulting in no electric field within. The concept of electric flux being zero indicates that the number of field lines entering equals the number exiting, but does not imply the presence of field lines inside. Under electrostatic conditions, the electric field is perpendicular to the surface, preventing any surface currents or voltage changes. Thus, the absence of an electric field inside a hollow conductor is a result of charge redistribution on its surface.
animboy
I can understand that if there is no charge inside an object then the electric FLUX is zero. Meaning the net integral of field vectors with respect to the area will be zero. But that doesn't mean there are no field lines inside the object at all! does it? I thought it just meant that the number of field lines going in equals the number of field lines coming out. But my lecturer drew it as if the field lines were instantly cut off when in in contact with the surface. Please explain this.
There are charges induced on the surface of the conductor, which is such that it screens out the electric field on the other side. So the electric field is cut off.
Rule of thumb: whenever you see discontinuity of electric field, there's some charge there.
Note in the above post mention of a CONDUCTOR...so charge redistributes on the surface.
Your statement implies electrostatic conditions...no surface currents flowing on the conductor. ...so maybe the charge density on the conductor varies from point to point, but the field E is at right angles to the surface in the static condition. Otherwise there would be an induced voltage...and charge on the conductor would be redistributed...there would be surface currents.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
