Graph and Differential equations for hyperbolas
shayaan_musta
Hello experts!
Hope all of you will be fine.
I have an equation i.e. xy=c
And we all know it is hyperbola.
Now I say "graph some of the hyperbolas xy=c". Then kindly tell me how can we extract more than 1 graph from this single equation? And you will write the differential equations for them. while here only 1 hyperbola is given i.e. xy=c.
If you have any confusion about the question the kindly tell me. I will try to clear more.
Thanks in advance.
Assuming c is some constant, you have y = c/x. This is a family of graphs, which varies based on values of c. I.E. y = 1/x, y = 2/x, ...y = c/x
Oh thanks. It is quite helpful.
y^{2}=4ax is also a parabola & and y=\frac{c}{x} too?
Is it?
Yes, y^2= 4ax would be a family of parabolas, all passing through (0, 0) having different foci.
I'm not sure what your question about y= c/x is. It is the same as xy= c, your original hyperbola system.
My real question as you can see that, how can you plot some hyperbolas families from general equation i.e. xy=c?
This could be y=c/x and therefore some families will be y=1/x, y=2/x, y=3/x...so on.
Where c=any arbitrary constant.
Am I right?
Yes, that is exactly what it is saying. They will be parabolas having the x and y axes as asymptotes, passing through (1, c) and (-1, -c), for each number c. Be sure to include some values of c negative and c= 0.
As you said c=0 this implies that y=0/x or y=0
Can y=0 be a parabola? Is it so?
