Solving Electrical Physics Problem: Find Electric Force on Point Charge
  • Thread starter Thread starter vtran0703
    Electrical Physic
vtran0703
My brother asked me this question and i completely have no idea how to do cause it is a very long time. Can anyone help, or give me an idea on how to do
A rectangular insulating sheet carrying a negative charge Q evenly distributed over its surface is formed into a cylinder, producing a thin walled hollow object of length L and radius R.
• We wish to find the electric force on a positive point charge q, located on the axis of the cylinder at one end.
a. Draw a sketch showing the tube, the victim charge q, and an appropriate coordinate system for describing the problem. In your sketch clearly show E at the location of q.
b. Choose and then clearly indicate the charge element dq you will use for the integration in your sketch.
c. Set up the integration. That is express F as a constant times an integral over a single variable.
Thank you
welcome to pf!
hi vtran0703! welcome to pf! :wink:
it's a fairly straightforward integration problem …
find the charge on a small area dzdθ of the cylinder, find the force at E from that charge, and then integrate over the whole cylinder
show us how far you get, and where you're stuck, and then we'll know how to help! :smile:
It's been quite a while since I saw these problem. To be honest, I wasn't good with them back then either, but I'll try, any help would be great
Remember that
\mathbf{E} = \int \frac{\lambda(\mathbf{r'}) d\mathbf{l}}{|\mathbf{r}-\mathbf{r'}|^2}\hat{(\mathbf{r}-\mathbf{r'})}
or alternatively
\mathbf{E} = \int \frac{\lambda(\mathbf{r'}) \mathbf{r}-\mathbf{r'}}{|\mathbf{r}-\mathbf{r'}|^3 }d\mathbf{l}
where r is the vector from the origin to a point in space and r' is a vector from the origin to the charge. So you make all the these infinitesimally different vectors as you sweep along the charge edge, and sum them up. A good idea for an origin is one where you can exploit symmetry in the problem, what's the most symmetric origin? What is the electric field from there?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
