How Does Current in a Wire Create a Magnetic Field?
Current in a wire produces a magnetic field due to the movement of electric charges, which creates a magnetic effect around the wire. This phenomenon can be understood through relativity, where the contraction of space between fixed positive charges leads to a perpendicular force relative to the current's direction. Maxwell's equations elegantly relate electricity and magnetism, showing how electric fields and magnetic fields influence each other, particularly in dynamic situations. Historical figures like Faraday also contributed to understanding the connection between these two forces through experimentation and theoretical insights. The interplay of electric and magnetic fields is fundamental to electromagnetic theory, which is extensively documented in various educational resources.
sambarbarian
hi , i wanted to ask why does current in a wire produces a magnetic field ?
and can anyone explain how maxwell related electricity and magnetism , easily (im in high school)
It can be elegantly explained via relativity;
From the point of view of electric current, the space between (fixed) positive charges contracts, whereas the density of the negative charge is unchanged. This results in a force that is perpendicular to the direction of the electric current.
Claude.
As well as Maxwell, there were many others who showed the inter-relation between electricity and magnetism (for example, Faraday). I guess this was the result of both experiment, and the imagination of these people to make the connection between electricity and magnetism. Probably you can go on wikipedia and search these people's names, and it will tell you specific examples of several of the ways in which they related electricity and magnetism.
About the current in the wire, you should think of currents and charges as sources of the magnetic and electric fields (in a certain sense of the word). Specifically, a charge will cause an electric field to flow into (or out of) the volume enclosing that charge. And a current (through some cross-sectional area) can cause a magnetic field to flow around that area. Also, the electric field depends on changes in the magnetic field and vice-versa, so if the fields are time-dependent, then it is a little more complicated.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
