How do unpolarized sunglasses reduce brightness?
  • Thread starter Thread starter dan1
    Brightness
Unpolarized sunglasses reduce brightness primarily by absorbing some light, which is why they appear dark. The lenses are made from materials that incorporate soluble organic dyes and metallic oxide pigments, which selectively absorb or reflect specific light frequencies. The effectiveness of light absorption varies based on the lens material used. Understanding the transparency of materials can provide insight into why certain sunglasses block light while others do not. Overall, unpolarized sunglasses function by limiting the amount of light that reaches the eyes, enhancing comfort in bright conditions.
dan1
Hi everyone!
I've been reading up on light and transmission, absorption and reflection and I was wondering how unpolarized sunglasses are able to reduce brightness. I tried Google-ing this but all I found was information about polarized sunglasses and how they reduce glare and work as UV protection but I have a fairly solid understanding of that. How do basic sunglasses work? Do they reflect some frequencies of light but let others through? If so, which ones?
Thanks for all your help!
Science news on Phys.org
Ordinary sunglasses absorb some of the light. That's why they look dark.
If you don't mind me asking, how are they able to do this and which frequencies of light do the absorb?
I typed in google "sunglasses materials", the first link was http://www.madehow.com/Volume-3/Sunglasses.html.
There you can read
Soluble organic dyes and metallic oxide pigments are added to the lens material to absorb or reflect light of certain frequencies.
The frequencies absorbed depend on the material composing the glass. If you really want to know why some material are transparent and others not, I suggest to take a look at http://www.quora.com/Why-are-some-materials-transparent-and-others-not and http://en.wikipedia.org/wiki/Transparency_and_translucency.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
