Conditional probability question
To calculate the conditional probability of the second journey time given the first, a relationship between the two journey times must be established. This requires understanding the underlying variables and their interactions rather than relying solely on abstract data points. The journey times may represent samples from the same random variable, necessitating the construction of a family of probability distributions. Normal distribution could be considered, but it may not be suitable due to the non-negativity of journey times. Establishing these relationships is crucial for accurate probability calculations.
bradyj7
Hi there,
I have the journey times of 2 journeys. Would somebody be able to show me by way of example how to calculate the conditional probability function of the second journey time given the first journey time?
https://dl.dropbox.com/u/54057365/All/jt.JPG
Appreciate your help
Thanks
John
You cannot deduce such a probability without constructing some relationship between the underlying variables. Wherever possible, this should be grounded in the knowledge of the physical system, not just abstract datapoints. In the present case, would I be right in guessing that the two times for a journey are effectively samples of the same r.v.? If so, you need to use the data to construct a family of probability distributions for these different r.v.s. E.g., they could be normally distributed with variances functionally related to their means. (But normal dist is likely not a good bet since they cannot go negative.)
