Please help transistor amplifier
The discussion revolves around designing a common emitter (CE) transistor amplifier with a specific voltage gain. Participants explore the calculations and component values necessary to achieve desired gains, including the relationships between resistors and transistor parameters. The conversation includes both theoretical and practical aspects of amplifier design.
  • Homework-related
  • One participant seeks guidance on how to achieve a desired voltage gain of 50 for a CE transistor amplifier, providing specific input parameters.
  • Another participant suggests that to achieve a gain of 2, the collector resistor (rc) should be 2K and the emitter resistor (re) approximately 1K, while introducing the concept of r'e.
  • There is a discussion about the input impedance of the transistor and how it complicates achieving the desired input impedance of 50K.
  • Some participants propose using two stages of amplification to reach a higher overall gain, with suggested configurations for each stage.
  • Participants discuss the calculations involved in determining the gain based on the load resistor (rl) and collector resistor (rc), emphasizing the need to consider parallel resistances.
  • There is a clarification on how to calculate r'e based on the bias current and thermal voltage, with some participants expressing uncertainty about the derivation.
  • Concerns are raised about the precision of gain in transistor amplifiers due to variations in components and temperature effects.
Participants express varying levels of understanding and agreement on the calculations and design approaches. There is no consensus on a single method to achieve the desired gain, and multiple competing views on the design process remain evident throughout the discussion.
Participants mention the importance of approximations in calculations, the impact of temperature on transistor behavior, and the challenges of achieving precise gains. The discussion also highlights the complexity of designing amplifiers with specific input and output impedances.
This discussion may be useful for electronics students, hobbyists, or professionals interested in amplifier design, particularly those looking to understand the nuances of transistor amplifier calculations and configurations.
  • #61
Averagesupernova said:
Collector resistor is Zout.
Zin is R1||R2||(beta*Re). In the schematic that Jony posted Re becomes Re1||Re2.
is so important to know resitance zin and zout, i am a begginer, how do you select zin zout is easy zout=RC but zin? you select, but zin how do you select
  • #62
michael1978 said:
yes thank you
oo joney sorry i have to ask you this
is this correct re2 = ( 220 * 11.5 ) / (220 - 12.5) = 12.1 = 12Ω.
of this one re2 = ( 220 * 11.5 ) / (220 - 11.5) = 12.1 = 12Ω.
  • #63
Michael, are you asking why Zin and Zout are important to know?
  • #64
This one is correct of course.
  • #65
jony can i ask you something, is possible for you to make one another amplifier but without Re2, with gain av 50, i know you maket very good the one, i understand all, but how to make without re2, you can select self the value but desired voltage to be 50, can you do it the same as in first example , if you want thank you PLEASE
  • #66
OK
Av = Rc/re = gm*Rc = Ic/26mV*Rc = (Ic*Rc)/26mV
50[V/V] = (Ic*Rc)/26mV
from this
(Ic*Rc) = 1.3
I choose Rc = 1K
So
Ic = 1.3/1K = 1.3mA
But as you can see this approach is not very good because give as low voltage swing.
We need to use Re1 or use a different type of a circuit. But lest as add Re1 resistor.
Now Av = Rc/(re+Re1)
And for Rc = 1K we can use this
Ic = 0.5Vcc/Rc = 5V/1K = 5mA
So re = 26mV/5mA = 5.2Ω
And
Re1 = Rc/Av - re = 1K/50 - 5.2Ω = 20 - 5.2Ω = 14Ω
This circuit is also not very good because low Re1 means that Hfe spread and temperature change will have significant impact on bias point stability. This is why I use Ve = 1V and add Re2 to reduce the voltage gain to 50[V/V]
  • #67
jony130 said:
ok
av = rc/re = gm*rc = ic/26mv*rc = (ic*rc)/26mv
50[v/v] = (ic*rc)/26mv
from this
(ic*rc) = 1.3
i choose rc = 1k
so
ic = 1.3/1k = 1.3ma
but as you can see this approach is not very good because give as low voltage swing.
We need to use re1 or use a different type of a circuit. But lest as add re1 resistor.
Now av = rc/(re+re1)
and for rc = 1k we can use this
ic = 0.5vcc/rc = 5v/1k = 5ma
so re = 26mv/5ma = 5.2Ω
and
re1 = rc/av - re = 1k/50 - 5.2Ω = 20 - 5.2Ω = 14Ω
this circuit is also not very good because low re1 means that hfe spread and temperature change will have significant impact on bias point stability. This is why i use ve = 1v and add re2 to reduce the voltage gain to 50[v/v]
thank you very much
  • #68
Also we can split Re resistor with a capacitor. And use Re1 = 14Ω and Re2 = Ve/Ic - re1 = 1V/5mA - 14Ω ≈ 180Ω
And now we can select R1 and R2
Vb = Ve + Vbe = Ic*(Re1+Re2)+ Vbe = 5mA* (180 + 14) + 0.65V = 1.62V
If we assume Hfe = 150
Ib = Ic/hfe = 5mA/150 = 34μA
R1 = (Vcc - Vb)/( 11*Ib) = 22KΩ
R2 = Vb/(10*Ib) = 4.7KΩ
  • #69
Jony130 said:
OK
from this
(Ic*Rc) = 1.3
I choose Rc = 1K
So
Ic = 1.3/1K = 1.3mA
And
AND value of r1 and r2 is r1=22k, and r2=4.7K and power supply 10V
  • #70
Yes for Vcc = 10V and hfe = 150
  • #71
THIS is the same example without re2, but you add in serie re2
i mean this laste circuit, and the first example without R2 has the same value value of r1 and r2 is r1=22k, and r2=4.7K and power supply 10V ,
and this is correct R1 = (Vcc - Vb)/( 11*Ib) = 22KΩ
of this R1 = (Vcc - Vb)/( 10*Ib) = 22KΩ
OK
from this
(Ic*Rc) = 1.3
I choose Rc = 1K
So
Ic = 1.3/1K = 1.3mA
And
thnx
  • #72
I don't understand the question?
  • #73
you show me first this example
OK
from this
(Ic*Rc) = 1.3
I choose Rc = 1K
So
Ic = 1.3/1K = 1.3mA
And
after you show the second example
is this the same like in example 1 and example 2
i mean this second example, and the first example without R2 has the same value value of r1 and r2 is r1=22k, and r2=4.7K and power supply 10V ,
and is this correct R1 = (Vcc - Vb)/( 11*Ib) = 22KΩ
do you understand you show 1 example in 2 party, first without re2 second with re2, so this one example, do you understand
  • #74
yes i ask you, i want to know
  • #75
This two equation holds only if Ve > 0.6V
R2 = Vb/(10*Ib)
  • #76
R2 = Vb/(10*Ib)
i ask you for gain av 50 without re, and you show me example
OK
from this
(Ic*Rc) = 1.3
I choose Rc = 1K
So
Ic = 1.3/1K = 1.3mA
And
ah joney i make you tired, is possibe to write me in one party not separate all this here, like in first example with re2, you explain me very good, but this is not in one party , i can understand better PLEASE
  • #77
OK
For this diagram the voltage gain is equal to
Av ≈ Rc/(re+Re1)
Rc = 0.1*RL = 0.1*10K = 1K
And
This circuit is not very good because low Re1 means that Hfe spread and temperature change will have significant impact on the bias point stability. This is why I use Ve = 1V for good bias stability.
To overcome this problem of a low value for Re1 = 14Ω and Ve = 70mV (Ve = Re1 *Ic = 5mA*14Ω = 70mV).
I add anther Re resistor in series with Re1.
Now we have
Ve = Ic * Re1+Re2 and we want Ve = 1V so
Re2 = Ve/Ic - Re1 = 1V/5mA - 14Ω ≈ 180Ω
And I use C2 capacitor to "remove" Re2 from gain equation for AC signal.
Av = Rc||RL/(re + Re1)
  • #78
Jony130 said:
OK
Av ≈ Rc/(re+Re1)
And
Now we have
JONEY THANK YOU, i understand everything, just this one no
R1 = (Vcc - Vb)/( 11*Ib) = 22KΩ, where come 11, how come this 11 can you explain me thnx
  • #79
First think first.
The one of the methods to become independent of hfe changes is to select voltage divider resistor (R1 and R2) in such a way that base current don't load our voltage divider to much. The maximum base current is equal to Ib_max = Ic/Hfe_min where Hfe_min is a minimum value for Hfe in data sheet.
And we select voltage divider current so that I_divader > Ib_max
In our example voltage divider current is I2 current .
But as you can see the current that flows through R1 resistor is equal to divider current plus base current.
Additional if we assume that divider current is ten times greater than base current.
I2 = 10 * Ib
the R1 resistor current I1 becomes
I1 = I2 + Ib = 10*Ib + Ib = 11*Ib
And this is why
R1 = (Vcc - Vb) / (10*Ib + Ib) = (Vcc - Vb)/(11*IB)
and
R2 = Vb/(10*Ib)
  • #80
Jony130 said:
First think first.
I2 = 10 * Ib
And this is why
and
R2 = Vb/(10*Ib)
this is a bit difficult to me, and how much is ib to your example, can you explain in similary way because i find difficult, sorry joney i try to understand but is difficult, ah value of ib is 1 is correct
  • #81
joney please can you explain this, i know you explain to me but i don't understond, this 11 and the value of ib HOW YOU CALCULATE 11AND IB PLEASE joney you help a lot to design amplifier. i am simple an beginner
ib is 0,034
johy this i know R1 = (Vcc - Vb)/( 11*Ib) = 22KΩ
(10*Ib + Ib) IS (10*IB(0.034)+0.034)=(0.34*IB)
but 11 i don't know can you explain me please CAN YOU ANSWER ME
  • #82
ib is 0,034
but 11 i don't know can you explain me, can you show me another example of ths 11 please CAN YOU ANSWER ME
  • #83
Do you understand first kirchhoffs law ?
Do you know how loaded voltage divider work?
  • #84
joney i know i think
and i do like i see in some book voltage divider like this
for example we need base current of 50MICRO
AND base voltage of 1.7V so now
for example if is 10vcc
r2 1.7v base/50micro is come 34ohm
r1 must have 8.3V/50MICRO is come 166ohm
so 10VCC/200=5MICRO
so the current in serie is the same, maybe i do somewhere mistake
i am curios to know your calculation how you get 10 and 11 in voltage divider, this is something new to me, but can you show another with example so i can understand, you show also the first example with gain of 50 do you rembember also there i see
R2 = Vb / ( 5 * Ib) = 30K
R1 = ( Vcc - Vb) / ( 6 * Ib) = 150KΩ
wher how you get 5 and 6, and second example r2 10 and r1 11, can you show me example just one the second i find self, i know you can do it, just with example in some easy way please joney i whait yesterday all day message from you, because i want to learn it, and i learn good how to select desired voltage and i am happy, but this no
valu of 11 and 10
joney plase show me example in easy way so i can understand thnx for reply...
  • #85
so 10VCC/200=5MICRO
Simply you forget about base current which loads the voltage divider in your calculations.
So to reduce this loading effect on output voltage we need increase the current that is flow through voltage divider or output current should be a small fraction of the voltage divider current.
So when we design voltage divider we assume that voltage divider current is larger then the load current.
Normally Divider current is 5 to 30 times larger then the load current.
So if we want 1.7V and load current is equal to 50μA and we choose voltage divider current 10 times larger then load current we have this
R2 = 1.7V/(10*Iload) = 1.7V/(10*50μ) = 1.5V/500μA = 3.4K
And from I Kirchhoff's Law we see that R1 resistor current is equal:
I_R1 = 10*Iload + Iload = 11*Iload = 550μA
So
R1 = (10V - 1.7V)/(550μ) = 15K
  • #86
So
o sorry joney i make you tired, i understand now, so if load current is 50μ we chose voltage divider current 10 larger then the load current, and we have
R2 = 1.7V/(10*Iload) = 1.7V/((this is 10 time larger)10*50μ(base current)) = 1.5V/500μA = 3.4K this i understand
but this i don't understand
10*Iload(50μA)+Iload(50μA)=11(how we get 11 now)*Iload(50μA)=550μA
i don't understand that 11 how we get? 10*Iload(50μA)+Iload(50μA)=0.55 not 11 sorry i don't know where i make mistake, where come this 11, i don't know how to calculate, i know 11*Iload is 550μA
thnx for answer
  • #87
Solve this pure math problem
B = 10A + A
Also from KCL we see that R1 must provide current for R2 resistor and also the current for the load.
So if Iload = 50μA and we pick voltage divider 10 times load current we have this:
I_R1 = Iload + 10 times load current = 11 times load current = 11*50μA = 550μA
  • #88
B = 10A + A
i am with calculator in my hand, i make mistake with my calculator but i don't understand i do it 0.050+10*0.050=0.55 how to do it ? CAN YOU TELL ME PLEASE HOW TO CALCULATE WITH CALCULATOR,
  • #89
Can you tell me how to calculate with calculator joney
  • · Replies 20 ·
  • · Replies 41 ·
9K
