Optimizing DC Current Through Neodymium Magnets for Efficient Power Transfer
Passing DC current through Neodymium magnets can be feasible, but caution is needed regarding heat generation. The Curie temperature for Neodymium magnets is around 80 degrees Celsius, and exceeding this can result in loss of magnetic properties. While 150mA is likely safe, currents approaching 2A may depend on the magnet's size and mounting. Using magnets as connectors may not provide reliable connections due to potential corrosion and insufficient contact points. A suggestion includes applying a conductive layer on the magnet's surface to enhance connectivity while maintaining magnetic force.
ebaqui
Hi
I want to pass DC current through a magnet, essentially using it as connector. The magnet I am using specifically is Neodymium (NdFeB) grade N42. The DC current I would like to pass through it is 100mA ~ 150mA (3V DC ~ 7V DC)
I would like to know if there is any downside to the magnetic effect of this permanent magnet?
Is there a way to determine how high i can go with the DC current in this situation without a noticeable detrimental effect on the magnetic effect of the magnet, like 1A ~ 2A?
Thank you
Nothing special should happen. But if you heat the magnet above its curie temp it will lose all its magnetic field.
The curie temp is especially low for neodymium magnets, for some types it's only about 80 degrees C.
So 150mA would most likely be OK. At 2A it will depend on the size,shape and mounting of the magnet how much it is heated.
ebaqui said:
Hi
Thank you
Welcome to the PF.
In addition to Jim's comments, keep in mind that what you are suggesting will not be a very good or reliable connector. To be reliable, the connection interface needs to have enough contact force to provide a gas-tight interface between the two conductors. If the interface is not air-tight, corrosion will happen in the interface (at different rates, depending on the contact material). Also, a good connector should have multiple points of contact. The surface of the magnet will be flat, with no dimples to give multiple contact points with gas-tight seals.
What is the application?
I am currently using spherical magnets 0.25" diameter. I cut a wire and connected magnets on each end, so when the magnets come in contact the circuit of leds will turn on. The 2A is for potentially running a number of leds.
Thanks for your help on this Jim
Welcome to the PF.
That is an interesting point , I did not consider. The magnets are 0.25" spheres, Ni plated. I could use a magnet each for the positive and negative terminal contacts, right?
I am using this for an led circuit to light my workbench.
Thanks for your help Berkeman
The new Apple Macbooks have a magnetic power connector. You could take a look at one of them to see how they do it.
It strikes me that you could put a thin layer of good conductor on the surface of the two magnets, connecting your wires to them and by-passing the magnet material yet still have enough force to keep the contacts together. I'm not sure you would need to worry too much about the shape / completeness of the contacts. It's a factor in all switches and a slight radius on each pole is usually sufficient for a contact.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
