Work Done On or By The System
The discussion clarifies the concepts of work done "on" a system versus work done "by" a system, emphasizing that work is always associated with a specific force acting through displacement. When lifting an object, the work done by gravity is negative, while the work done by the lifting force is positive. If the force direction is unclear, determining the sign of work can be approached by analyzing energy changes: negative energy change indicates work done by the system, while positive indicates work done on the system. The first law of thermodynamics is referenced to illustrate these concepts, particularly in the context of a four-stroke engine where work is exchanged during different strokes. Understanding the system's boundaries and the forces acting on it is crucial to avoid misconceptions, such as creating a perpetual motion machine.
brentd49
Work Done "On" or "By" The System
Will someone help solidy this concept of Work 'On' a system and Work 'Done' by a system.
If I lift an object from some defined zero potential. Then the work BY the system is -mgh, because gravity 'g' is in the reverse direction as the displacement 'h', but work done ON the system is +mgh because it is the opposite of work BY the system.
But what do I do if I don't know the work done by the system, i.e. there is not a given 'g' vector pointing down? How can I tell if the work is plus or minus?
Work is always associated with a particular force. The work done by the force is:
W = \int \vec{F}.d\vec{r}
In your example of lifting an object, the work done by the gravitational force is negative, while the work done by the lifting force is positive.
Can you give an example of what you mean? As James R stated, work is always associated with a particular force acting through a displacement. If the displacement is in the direction of the force, the work is positive; if opposite to the force, negative.
It's sometimes easier to find the change in energy first (whether +ve or -ve) and decide whether it is positive or negative afterwards.
energy lost ===> ΔE is negative ==> work done by system
energy gained => ΔE is positive ==> work done on system
A good example is the first law of thermodynamics:
change in internal energy = heat added to system - work done by system; OR, equivalently:
change in internal energy = heat added to system + work done on system
E.g. in a four-stroke engine, if you consider a single cylinder,
work is done BY the system during the power stroke (i.e. BY the gas expanding on the piston to move it outwards and thus transferring energy outsdie the system to the other cylinders) and work is done ON the system during the exhaust stroke (i.e. by the piston (the force is supplied by the power stroke of a different cylinder) ON the exhaust gas as it is pushed out of the cylinder).
Likes hellomrrobot
For me it's always easiest to draw a picture. Start with a big circle that defines the boundary of your system, then place objects in it. And if often doesn't matter whether something is placed inside or outside, as long as you are consistent.
Since gravity seems like an all-encompassing force, it can get confusing, but if the system is just the box, then both you lifting and gravity acting against you are outside the system. And if you put you in the system, you need to put gravity in the system as well. Otherwise, you could accidentally create a perpetual motion machine (no inputs, only outputs).
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
