Calculating Work Done on Body by Friction: Compare Results
  • Thread starter Thread starter stunner5000pt
    Work
stunner5000pt
The froce of friction on a body (moving along a surface at constant speed) can be approximated by \vec{F} = -F \hat{v}, where F is a positive constant and \hat{v} = \frac{\vec{v}}{|\vec{v}|} is the unit vector in teh direction of \vec{v} = \dot{\vec{r}} (the velocity of the body)
Prove that hte work done in moving the body from r to r+dr (along a given path) ie dW = F . dr= -F ds in this case where
ds^2 = d\vec{r}^2 = dx^2 + dy^2 + dz^2 where ds iteh element of arc length along the path of the body
Hint: \frac{\frac{d\vec{r}}{dt}}{|\frac{d\vec{r}}{dt}|} = \frac{d\vec{r}}{|d\vec{r}|} and |d\vec{r}| = \sqrt{d\vec{r} \bullet d\vec{r}} = \sqrt{d\vec{r}^2} = ds
ok since v hat can be written like the hint and the denominator can be written like ds so
\vec{F} \bullet d\vec{r} = -F \frac{d\vec{r}}{ds} \bullet d\vec{r}
since dr dot dr is ismply dr^2 which is ds^2 we get what we want.
Is this fine?
If the body is moved along a level floor (in which we take to be the xy plane) from the point (0,0) to (1,1) along two different paths
(i) The straight line through (0,0) and (1,1)
(ii) along teh parabola y = x^2
Calculate the work done in teh two cases and compare the results
Im wondering if they mean the work done by the force of friction of the work done by the person pushing the box
If it was the work done by the friction could we even calculate it without any time given?
Please help! Thanks in advance!
i asked my prof and he says that the work done should be the work done by the friction
so in this case for the straight line y=x, since we derivaed the dW = -F ds
but what is ds?
is it something like this?
ds = \sqrt{dx^2 + dy^2}
in cartesian coordiantes what would be the limits of integration... since x and y would be inmtergrated separately?
so then would it be like this?
W = \int_{y=0}^{y=1} \int_{x=0}^{x=1} \sqrt{dx^2 + dy^2}
but htis doesn't make sense because the differe\ntials themselves can't be under roots?
Please help!
Thank you!
can anyone help... offer some guidance as to what to do here?
your help and input is always greatly appreciated!
a friend of mine said that the answer for the part where the block is moved along the straight path form (0,0) to (1,1)
W = \int_{0}^{1} \int_{0}^{1} F (1,1) \bullet (1,1) dx dy but I am not quite sure about why he did the dot product?
for the y=x^2 path he suggested that one does this
W = \int_{0}^{1} \int_{y=0}^{y=x^2} F (1,1) \bullet (1,1) dx dy
same thing here, how did he get the dot product?
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
