What's Wrong with this Argument? Understanding the Physics of Work
The discussion revolves around a physics problem where a teacher incorrectly implies that a constant force of 15 N will always result in the same distance moved (4/3 m) for any mass when 20 J of work is done. Participants clarify that while the calculation using W=F*d is correct, it overlooks factors like friction and the object's weight, which can affect the actual distance moved. The conversation emphasizes that in horizontal motion, the resultant force of 15 N may include both the applied force and any resistive forces. Ultimately, the misunderstanding stems from the teacher's failure to adequately explain these additional forces. The importance of considering all forces in real-world scenarios is highlighted.
Riddl3r
Our teacher made an unconvincing argument based on this example:
If a horizontal force of 15 N were a applied to a 2 kg block, and the work done was 20 J, what distance did the object move?
2. The attempt at a solution
Using W=F*d the teacher solved this: 20 J=15 N*x -> x=4/3 m.
This implied that if I applied 15 N to an object of any mass and did 20 J of work, the distance I could move the object is always the same. There seems to be something fundamentally wrong with this statement. But I'm not seeing what it is, I know it's there - I'm think that somehow I need to do something with the weight of the object. I mean if it were to be realistic I would have to calculate friction and gravity too...
Can somebody please tell me what I missed out?
That's correct.
Usually we neglect friction and the gravity doesn't play a role here because this is a horizontal motion.
it's more like a resultant force of 15N which moves the body 4/3 m when 20 J of work is done. the 15 N resultant force may include the force you apply - any resistive forces for example.
Oh I see what you're saying, I guess my teacher didn't convey that point very well^^
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
