Have also made this...
As you can see it is a Phenolic spacer of 8mm thickness that I designed to stop heat transfer from the alloy head to the alloy Broad Band Manifold (BBM) system. A BBM provides a long air path at low engine revs and uses a vacuum line to move butterflies and provide a short air path from throttle to combustion chamber at mid - high revs. It is all computer controlled from 3D tables, but you can see an example of it kicking in by looking closely at a dyno reading...
This example is probably not the clearest, but you can see a fluctuation around the 4000rpm mark. It may drop or rise in revs depending on throttle position, load, etc.
Where was I?
Oh yes - I have been testing this spacer installation of mine for a while now and am happy to report that the highest temp reading from the middle of the throttle butterfly has dropped from the high 60's (degrees in Celsius) to the mid 30's. This astounded me, and it is simply too good to believe so I am now lurking around with pocket protector wearing Physics Dudes on the net rather than telling the skinned knuckle and tattoo brigade over at
http://www.fordmods.com !
Obviously temperature drops of this nature are going to be good for an internal combustion engine. I am actually on this site as a result of searching for air expansion due to temperature so I can be armed and ready for the disbelieving masses...
It appears as tho there's a few here too...
"""If it worked then car manufacturers would have been doing it already""" etc etc etc.
CAR MANUFACTURERS do not put scoops out their bonnets etc etc for a number of reasons. One of which is simply SALES. Middle aged families who buy cars don't really want scoops and holes in the bonnet. Simple!
Virtually all serious race or performance cars (even from manufacturer) have such vents near front or mid point of bonnet and intakes further up the bonnet for Cold Air Induction (CAI) or intercoolers. As previous writer, above, states """you need fins to get a large contact area and this would impede airflow""". Yeah mate, quite right. That is why Forced Induction (Turbo, Supercharger) use an alloy "radiator" in the air supply as the air is heated by the process of forcing it into engine at 20PSI.
Another reason car manufactures don't actually do things to full extent they could is cost of manufacture. There are very few people who will pay the thousands more per vehicle for the 10% jump in performance. Most people wouldn't even notice! Some people buy "racing cars" just for the stickers, I guess...
The only real way to see examples of things done properly is to go to your local "production car" race days. Guarantee you most of these guys will have changed the CAI and exhaust outlets.
Not all of them would have spent days or weeks researching their own vehicles properties first and simply copied their mates, and even fewer would have spent hours on
https://www.physicsforums.com !
I do not know what I am doing. I hadn't even changed a brake pad on a car until a year ago. People shouldn't just take stuff for granted but re-think, re-design and attempt to improve upon.
"Hey, that apple fell on my head."
"So what, they always do that. It's normal."
"Oh. Right, fair enough. What's for lunch?"
