| Thread Closed |
even if sustained nuclear fusion were possible, commericially viable? |
Share Thread | Thread Tools |
| Jan7-09, 12:29 PM | #1 |
even if sustained nuclear fusion via deuterium-tritium type reactions were possible, and the energy that is released exceeds the energy that is put in, and this energy is harnessed as a conventional water-steam generator, would such a design be commericially viable, based on the current cost of experimental fusion reactors? If this technology can be done for say 2 billion (the LHC was around 6 billion I understand) making use of superconducting magnets in a torus, would such an expensive technology ever pay itself off, in comparison to fossil fuel burning plants?
| Jan7-09, 01:13 PM | #2 |
Recognitions:
The experimental fusion reactors are expensive because they are experimental.
The core of a fusion reactor should be cheaper and easier to build than a fission reactor. Most of the engineering, steam+generator set distribution grid etc, is the same for any station. Then if your fuel is free (at least for D-D reactors). The biggest cost is probably still the lawyer's bills for the public enquiry . |
| Jan7-09, 07:07 PM | #3 |
Fusion reactors actually consume more energy than they produce.
So, even if they could be constructed for free, and the fuel was free and there was no maintenace expenses and operators all worked for free, they would still not make economic sense. Also, the cost of extracting deuterium from water is not simple and actually very expensive. I'll wager a wild guess, that unless fusion reactors produce at least 10 times as much energy as they consume, they will not be economic. |
| Jan8-09, 01:47 AM | #4 |
Your wild guess is about right ! People estimate that the Q-factor, which is essentially the ratio of the energy usefully extracted over the energy used to heat the plasma, must be around 15-20 for a commercial plant. The highest value reached as of now by JET is 0.7 if my memory is right. In order for this to happen, one needs a self-igniting plasma, that is, one needs a plasma that when it is heated initially, produces enough self-heating to sustain the fusion, and then one needs to keep this going on long enough.
| Jan8-09, 10:52 AM | #5 |
| Jan8-09, 10:58 AM | #6 |
Recognitions:
I wonder what the initial input is for a coal fired station?
Having tried to light a coal fire with matches->paper->sticks->coal do they cheat and just use a big bottle of barbecue lighter fluid? |
| Jan8-09, 08:25 PM | #7 |
The burning coal in a generating station has been ground into dust and is entrained with compressed air. Toss in a match and off you go. Or, I guess you could think of the "Q" in terms of the power from the grid to start the pulverizers and fans. Or the diesel-gens you light off to do that if you're doing a black start...
| Jan9-09, 01:01 PM | #8 |
1. The cost of tokamaks is intrinsic to the design. Once the design requires a neutron blanket, and D-D / D-T tokamaks do, they lose, as they must be much larger than a LWR fission reactor core of comparable power. 2. It appears Tokamaks can only come in one size - large - well above 1000MWe. Commercial viability requires financial viability; a large tokamak fusion plant is still going to require too much money up front and too much time to build. Relevant comments from LANL fusion researcher Rick Nebel: http://www.talk-polywell.org/bb/view...ighlight=#9834 |
| Jan9-09, 02:30 PM | #9 |
Recognitions:
I was basing it on the inside of a tokamak being an empty metal tube. You don't have the complex fuel structure and hot primary cooling circuit. All the expensive complex stuff is outside the tokamak where it doesn't get so much of a dose so doesn't need special materials or decommisioning. The inside of the chamber does but you just fill it with concrete when you are done. His other point about the cost doesn't really add up. The first atom bombs, computers, jet aircraft, rockets all needed a war time national project to build but they are now a little easier. It is probably more commercialisable than LANL's laser initiated pellet alternative. |
| Jan9-09, 04:36 PM | #10 |
http://www.sourcewatch.org/index.php...e-EIA_existing http://www.gepower.com/prod_serv/pro...c/en/index.htm On the low end we have ~1MW wind turbines, which obviously include the generator. |
| Jan9-09, 05:06 PM | #11 |
Recognitions:
A big chunk of the UK's power comes from 3 coal fired stations near where I used to live - they are 2.5-4Gw (coal works best with big stations) most of the rest comes form paired reactors or 1500Mw gas fired stations. The real achievement of ITER is probably getting that many countries to agree on building something! |
| Jan10-09, 07:31 PM | #12 |
Recognitions:
There's NO REASON that we can't ultimately extract energy from fusion - after all that's what Hydrogen bombs do - you get more FUSION energy from Hydrogen bombs than you put in. However, we can't control the reaction at present to output a manageable amount of energy. But that will change in the future. The National Ignition Facility at Lawrence Livermore National Laboratory is expected to reach fusion "ignition" - more energy out than went in: https://lasers.llnl.gov/ Actually, extraction of deutrerium is NOT prohibitively expensive - Canada separates heavy water from light water ALL THE TIME for their CANDU reactors. Dr. Gregory Greenman Physicist |
| Jan10-09, 08:08 PM | #13 |
Recognitions:
Tokamaks aren't the only fusion reactor design. Lawrence Livermore National Laboratory is working on a concept called LIFE: https://lasers.llnl.gov/missions/ene...e_future/life/ https://lasers.llnl.gov/missions/ene...life_works.php Dr. Gregory Greenman Physicist |
| Jan21-09, 12:55 AM | #14 |
| Jan21-09, 09:12 PM | #15 |
| Jan21-09, 11:11 PM | #16 |
I suspect what will ultimately decide it is the cost of the fuel and dealing with the waste. Fission/fusion reactors will require a staggering expense to develop, but the cost is non-recurring - once you've figured it out, you build plants and make energy. Economical DD fusion is hard to imagine right now, but the fusion fuel is close to free and serves to burn up the fission byproducts - if I extend my timeframe far enough and assume our clever descendants will work out the details, it's hard to see why this isn't the winning bet. I could be wrong.
| Thread Closed |
| Thread Tools | |
Similar Threads for: even if sustained nuclear fusion were possible, commericially viable?
| Thread | Forum | Replies | ||
| nuclear fusion | Advanced Physics Homework | 2 | ||
| nuclear fusion | Nuclear Engineering | 5 | ||
| Nuclear fusion | General Physics | 10 | ||
| nuclear fusion | Introductory Physics Homework | 3 | ||
| when will fusion power be economically viable? | Nuclear Engineering | 6 | ||
