Definition of the determinant i = 1
jeff1evesque
definition of the determinant i = 1"
Lemma:Let B be an element in M_n_x_n(F), where n >= 2. If row i of B equals e_k for some k (1<= k <= n ), then det(B) = (-1)^i^+^kdet(B_i_k).
Proof: The proof is by mathematical induction on n. The lemma is easily proved for n = 2. Assume that for some integer n >= 3, the lemma is true for (n-1) x (n-1) matrices, and let B be an nxn matrix in which row i of B equals e_kfor some k (1<=k<=n). The result follows immediately from the definition of the determinant i = 1.
Questions:
1. Can someone help me understand/prove the italized text above.. "...follows from immediately from the definition of the determinant i = 1"
2. And how does det(B) = (-1)^i^+^kdet(B_i_k).? Why isn't there a coefficient in that equation B_i_,_k? This questions is not necessary I guess- since If i follow and understand the proof in the book the logic will work out- but I always thought that in calculating a determinant there would be a scalar coefficient- thus: det(B) = B_i_,_k(-1)^i^+^kdet(B_i_k).
thanks,
JL
Hi jeff1evesque! :smile:
(try using the X2 tag just above the Reply box :wink:)
jeff1evesque said:
… I always thought that in calculating a determinant there would be a scalar coefficient- thus: det(B) = B_i_,_k(-1)^i^+^kdet(B_i_k).
Yes, that's right …
but in this case, Bik is 1. :wink:
Yes, that's right …
That would imply that every e_k = 1. The symbol e stands for the standard ordered basis- for our particular row 1 correct? So for row i, are all the elements e (standard ordered basis) equal to 1? But how can you assume the ordered basis for our row is all 1's? The e's simply denote the order of the basis for this particular row F^n.
Thanks so much,
JL
Perhaps I'm misunderstanding the notation, but I think it means that eg if row i of B equals e2, then row i is (0,1,0,0,…)
