Electric Field: Does a Circular Set of Charges Appear as One?
  • Thread starter Thread starter rockyshephear
    Charges
A perfectly circular set of point charges can indeed appear as a single point charge when viewed from a sufficient distance, due to the spherical symmetry of the charge distribution. This phenomenon is explained by the Gauss divergence theorem, which states that the electric field at a given radius from a symmetric charge distribution resembles that of a single point charge located at the center. The effective charge of this point charge is equal to the total charge within the sphere of that radius. Similarly, a circular set of dipoles would also exhibit similar behavior under the right conditions. Understanding these concepts is crucial for analyzing electric fields in physics.
rockyshephear
Would a perfectly circular set of point charges appear to be one point charge if you could see the electric field?
Same question with perfectly circular set of dipoles.
My question is posed because I saw an illustration
http://images.google.com/imgres?img...ric+Field&hl=en&rlz=1G1GGLQ_ENUS337&sa=X&um=1
that seems to indicate that a collection of charges can show as one point charge.
Mathematics news on Phys.org
This is a physics question, not a math question.
If you are far back enough, then it is like a point source.
I posted in the physics section.
Any system with a charge distribution that has spherical symmetry will have the same electric field at any given radius "r" as you would get from a simple system containing just one point charge (at the center), where the value of this point charge is equal to the sum of all the charge which lay within a sphere of radius "r" in the original system.
BTW. This is a direct consequence of the Gauss divergence theorem. http://en.wikipedia.org/wiki/Divergence_theorem
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
