| Thread Closed |
row of a matrix is a vector along the same degree of freedom |
Share Thread | Thread Tools |
| Oct29-09, 02:51 PM | #1 |
A particular introduction to matrices involved viewing them as an array/list of vectors (column vectors) in Rn. The problem I see in this is that it is sort of like saying that a row of a matrix is a vector along the same degree of freedom (elements of the same row are elements of different vectors all in the same dimension). So from this, technically, the scalar product of a column vector v and row1 of a matrix A should only exist as a product between the elements of row1 of the matrix A and row1 of the column vector v...which doesn't seem right (since matrix-vector multiplication Av is defined as a column vector of dot products between the vector v and rows of A). How would one geometrically interpret a matrix?
| Oct30-09, 05:03 AM | #2 |
![]() Technically, row vectors are transpose vectors, so the first row of A is is not the vector a1 (say), but the transpose vector a1T. Then your scalar product in matrix form is (a1T)v, but in ordinary form is a.v ![]() , except that I always think of a matrix as being a rule that converts one vector into another vector.
| Oct30-09, 06:00 AM | #3 |
I understand matrices as operators, like you may have basis vectors (x,y,z all normal), you can have basis functions (such as sin(nx) for n=1,2,3...) which any periodic function can be decomposed into using Fourier series. Then the function can be represented completely by a column vector containing the amplitude of each frequency, and the matrix multiplication will output a new function. So in that sense you might represent a matrix geometrically by a series of "before and after" functions!
Then again this is just fun speculation... the most fundamental way of expressing a matrix geometrically is probably by a discrete 2-D plot, f(m,n) = the (m,n)th element of the matrix. |
| Oct30-09, 09:52 AM | #4 |
I see...good stuff so far...Thanks for all the replies.
| Nov1-09, 04:56 AM | #5 |
Hi Gear300!
![]() I've found a page on john baez's excellent website which shows the relation between the ordinary and the matrix representation of the same equation, and where the transpose fits in … if ω is the (instantaneous) angular velocity, then the rotational kinetic energy is both: 1/2 ω.L and (without the "dot")1/2 ωTL = 1/2 ωTÎω where L is the (instantaneous) angular momentum, and Î is the moment of inertia tensor, both measured relative to the centre of mass. |
| Nov1-09, 08:48 AM | #6 |
Thanks a lot for the link tiny-tim.
So, its sort of like saying that for an m x p matrix with n being a dimensional space, you could label the rows (going down) from n = 1 to n = m and you could also label the columns (going across) from n = 1 to n = p, right? |
| Thread Closed |
| Tags |
| john baez, transpose |
| Thread Tools | |
Similar Threads for: row of a matrix is a vector along the same degree of freedom
| Thread | Forum | Replies | ||
| The Matrices | Calculus & Beyond Homework | 12 | ||
| Matrices - unitary matrices | Calculus & Beyond Homework | 6 | ||
| Matrices | Calculus & Beyond Homework | 3 | ||
| some T/F on matrices | Calculus & Beyond Homework | 0 | ||
