Physics Forums Logo
* Register * Upgrade Blogs Library Staff Rules Mark Forums Read
image   image
Go Back   Physics Forums > Engineering > Electrical Engineering
Reply
image Does the stuff you solder with have lead in it Share It Thread Tools Search this Thread image
Old Nov21-09, 07:36 PM                  #1
Jurrasic
Jurrasic is Offline:
If you want to soldier something, then, how can you check to be that whatever you are soldering has no lead present?
Old Nov21-09, 07:38 PM                  #2
turbo-1
turbo-1's Avatar
turbo-1 is Offline:
Recognitions:
PF Contributor PF Contributor
Re: Does the stuff you solder with have lead in it
I repair old tube amps. Yes, the solder has lead in it.
Old Nov21-09, 07:45 PM                  #3
f95toli
f95toli's Avatar
f95toli is Online:
Recognitions:
Buy lead-free solder...
The type of solder that is used commercially nowadays does not contain any lead. But if you are a hobbyist you can still buy solder with lead in it (the most common type being 60/40)
Also, you should avoid mixing lead-free and leaded solder, which can be a problem if you are reparing something.
Old Nov21-09, 09:02 PM                  #4
Integral
PF Mentor
Integral's Avatar
Integral is Online:
I have encountered what I believe to be lead free solder on my last couple of fixes. It must have a higher melting point then regular 60/40 solder as my poor old soldering iron barely has the power to melt it. I found that by adding regular solder I could get it to melt and was able to remove it. I replaced it with regular solder, both my repairs, a power supply for a plasma big screen and a old motherboard seem to be doing fine.
What are the problems with mixing the two?
Old Nov21-09, 09:41 PM                  #5
dlgoff
dlgoff's Avatar
dlgoff is Offline:
Recognitions:
So Jurrasic. You didn't say what you are soldering. I use silver solder for copper tubing.
Old Nov22-09, 02:46 AM                  #6
berkeman
PF Mentor
berkeman's Avatar
berkeman is Online:
I'm just guessing, but I think it may be the different melting temperatures. If you have a mix, then part of the solder joint may have a good fillet, and part may not. Especially if the PCB undergoes stress, shock or vibration (like in portable devices), inadequate fillets can lead to premature solder joint failure.
Old Nov22-09, 05:15 AM                  #7
Born2bwire
Born2bwire is Offline:
Recognitions:
Uggg, yeah. I have tried lead free solder a few times and did not like the performance or behavior of the solder. I'm sticking to lead solder for now.
image image
Reply
Thread Tools
Similar Threads for: Does the stuff you solder with have lead in it
Thread Thread Starter Forum Replies Last Post
Recapture Pb (lead) from hydrocerussite (powered white lead) - HOW ? hawkin Materials & Chemical Engineering 0 Oct18-08 12:21 PM
The right size solder? Jdo300 Electrical Engineering 2 Dec6-07 02:12 PM
Solder iron |)a\/1d Electrical Engineering 7 Sep13-07 04:16 PM
My house has Lead Solder on One of the Pipes dimensionless General Discussion 9 Sep24-06 12:39 PM
[SOLVED] You can't solder in zero-gee Doug Goncz General Physics 0 Aug17-04 12:26 PM
Powered by vBulletin Copyright ©2000 - 2010, Jelsoft Enterprises Ltd. © 2009 Physics Forums
Sciam | physorgPhysorg.com Science News Partner
image   image
