Sound waves propagated as transverse waves
Sound waves cannot propagate as transverse waves in gases because gases lack resistance to shear forces, which are necessary for such wave propagation. In contrast, sound waves in solids can be transverse due to the tightly packed molecular structure that allows for vibrational movement along bonds. The discussion highlights the distinction between longitudinal waves, which are typical for gases, and the ability of solids to support both longitudinal and transverse waves. Understanding the molecular behavior in different states of matter is crucial to grasping why sound behaves differently in gases compared to solids. Overall, the properties of molecules and the nature of shear forces play a significant role in wave propagation.
koat
hello
can somebody tell me why sound waves can't be propagated as transverse waves?
thanks in advance
koat said:
hello
thanks in advance
Welcome to the PF. Tell us your thoughts on the question. What is sound? What kind of waves generally propagate sound? What kind of things are propagated by transverse waves? Can you see anything at the molecular level (in air or water or solids) that would affect how sound is transmitted?
EDIT -- this sounds a bit like schoolwork, so you need to show some effort at helping to figure out the explanation.
Who said they can't?
my textbook
I have no idea :(
I just know that water waves and waves in the em spectrum are transverse waves
Think about how a transverse wave propagates. For this example, don't worry about EM waves (which propagate differently than sound), just consider transverse waves moving down a string as you oscillate one end of the string up and down. What force makes the string as a whole propagate the wave? Why is it that when I pull up on one side of the string, other pieces of the string also move up?
Is this force present in air?
koat said:
my textbook
if that's true, your textbook is using a restricted definition of sound waves.
Sound waves in a gas cannot support transverse waves. This is because a gas is not resistant to shear forces. berkeman asked about molecules. What are the properties of molecules in a gas, and what is shear force?
Sound waves in a solid can be transverse waves.
In a gas the molecules are further apart than in solid.
But I don't understand why there are transverse waves in the solids...
why is gas not resistant to shear forces?:confused:
This is a classwork question so you have to do some work first. What is a shear force?
is it a force that pushes something?
Recently the people of Haiti and Chile called them earthquakes. They are all too real.
Did you read my linked thread?
If you don't understand the difference between shear and normal force then try this explanation.
In a fluid (liquid or gas) the particles are distributed at random as in my first sketch. They can move freely in any direction and there will be local 'clumps' where the molecular density is temporarily higher or lower than average.
A pressure or longitudinal wave is nothing more than organising these clumps to form a regular pattern of higher and lower density (pressure).
In a solid there is a regular array and the molecules are not free to move about. Instead they can 'vibrate' about their mean positions, as dictated by the bonds with their immediate neighbours.
Vibration along the bonds axes is energetically preferred.
So if we can organise a wavetrain of vibrations to pass down the array it can be either longitudinal or transverse as shown.
Search on "shear wave" and there will be a Wikipedia article. Go to the article. The first animated picture is a shear wave.
Note, it might look like a the waves on the surface of water, but all the motion is in the plane of your video monitor. The motion of the grid is perpendicular to the direction the wave propagates.
