Help on conversion with mass involved
  • Thread starter Thread starter rt3ll3z
    Mass
The discussion focuses on calculating the mass of sand grains needed to match the surface area of a cube measuring 1.50 m on each edge. It begins by establishing the properties of the sand grains, which are spherical with an average radius of 45 µm and made of silicon dioxide. The volume of a single grain of sand is derived using the formula for the volume of a sphere. Additionally, the density of silicon dioxide is noted as 2600 kg/m³, which is relevant for determining the mass of the sand. The key calculations involve finding the surface area of the cube and relating it to the total surface area of the sand grains.
rt3ll3z
Grains of fine California beach sand are approximately spheres with an average radius of 45 µm and are made of silicon dioxide. A solid cube of silicon dioxide with a volume of 1.00 m3 has a mass of 2600 kg. What mass of sand grains would have a total surface area (the total area of all the individual spheres) equal to the surface area of a cube 1.50 m on an edge?
answer is in kg
volume of sphere=4/3*pi*r^3
answer is in kg
So what is the volume of 1 grain of sand?
What is the density of the Silicon dioxide?
What is the surface area of 1 sphere?
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
