Forces with angles, Find the acceleration
The discussion revolves around calculating the acceleration of a 4.00 kg mass acted upon by two forces: 6.50 N at 55° West of South and 7.00 N at 25° North of West. Initial calculations for the force components were incorrect due to inaccuracies in the diagram and misunderstanding of vector directions. The x-components were miscalculated, leading to an erroneous net force and consequently an incorrect acceleration value of 2.9 m/s². A more accurate diagram and adherence to vector conventions are necessary for correct calculations. Properly resolving the forces will yield the correct acceleration.
plumeria28
Two forces act on a 4.00 kg mass which is sitting at rest on a horizontal frictionless surface. One force is 6.50 N directed 55° West of South, the other is 7.00 N directed 25° North of West. What acceleration does the mass receive?
sin = o/h
cos = a/h
tan = o/a
a = F/m
I drew forces (not accurately) on paint (attachment) to help me solve this question then did the following calculations:
Fapx1
sin = o/h sin35° = o/6.5N o = 3.7N
Fapx2
sin = o/h sin25° = o/7N o = 3N [N]
Fapx = Fapx1 + Fapx2
Fapx = 3.7N - 3N
Fapx = 0.7N
Fapy1
cos = a/h cos35° = a/6.5N a = 5.3N [W]
Fapy2
cos = a/h cos25° = a/7N a = 6.3N [W]
Fapy = Fapy1 + Fapy2
Fapy = 5.3N + 6.3N
Fapy = 11.6N
tan = o/a tan = 11.6/0.7 tan = 86.5°
sin = o/h sin86.5° = 11.6/h h = 11.622N
a = F/m a = 11.622N/4.00kg a = 2.9 m/s^2
_____________________________________________________________________________
I was wondering if I did the question right. Did I get the right answer?
sin = o/h
cos = a/h
tan = o/a
a = F/m
Fapx1
Fapx2
Fapx = 3.7N - 3N
Fapx = 0.7N
Fapy1
Fapy2
Fapy = 5.3N + 6.3N
Fapy = 11.6N
problems:
Firstly, you have not helped yourself with your diagram.
"Your" 55o angle is smaller than your 25o angle, so when you got two x-components of 3N and 3.7N you did not recognise that at least one of them was wrong, as the x-component of the 6.5N force is way less than the x component of the 7N force. The Y components don't llok good either. You seem to have added the y components and subtracted the x ??
I said the diagrams are not accurate, I just drew them so it would be visually easier to do the calculations. And I added the y components because they were both going in the same direction (west) and subtracted the x components because they were going opposite directions (south and north).
But your diagram clearly shows the x components both going west, and the y-components going in opposite directions - North and South.
You need to draw a more accurate diagram and stick to the conventions you state on that diagram if you want to get anywhere with this problem.
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
