Charges moving parallel to magnetic fields and direction of magnetic force
Moving a charge parallel to a magnetic field results in zero magnetic force due to the nature of the cross product in the magnetic force equation, F = qv x B, which yields zero when the velocity vector is parallel to the magnetic field vector. This phenomenon is supported by experimental data and can also be understood through the principles of relativity, where the behavior of charges is influenced by their relative motion. The discussion highlights that when observing a charge's interaction with a stationary line of charge from different frames of reference, the perceived forces can change, illustrating the relativity of motion. Additionally, opposite charges of equal magnitude produce different magnetic force directions due to their distinct electric field properties. Overall, the conversation emphasizes the interplay between mathematical principles and conceptual understanding in physics.
nateja
I hope this isn't in the wrong forum, it's not a problem, just a conceptual question for physics 2.
I have a few questions that I cannot find answer for in my physics book or online.
1) Why does moving a charge parallel to the magnetic field result in zero magnetic force?
Is this quality based on experimental data like the magnetic force equation (something that the book mentions: says the mag-force equation was not developed theoretically, but experimentally)? F = qv x B. I know that due to the cross product, the force will just be 0, but is there another explanation besides just the math?
Why do opposite charges of equal magnitude result in different directions of magnetic forces? Is this a property of the electric fields from the oppositely charged masses (positive are isotropic and negative all point toward the negative charge)?
hi nateja! :smile:
nateja said:
1) Why does moving a charge parallel to the magnetic field result in zero magnetic force? … I know that due to the cross product, the force will just be 0, but is there another explanation besides just the math?
here's a conceptual answer …
a velocity-dependent force is an inevitable consequence of relativity (good old-fashioned Newtonian relativity, not the einsteinian sort) …
imagine a stationary line of negative charge, and a negatively-charged particle moving perpendicularly towards it
obviously, it is repelled, so it slows down, is momentarily stationary, then speeds up again, moving away, all on the same perpendicular line
now look at it from a frame of reference in which the line is moving along itself at speed v …
what happens to the moving charge? :wink:
Thanks! my professor explained this in class with the same frame of reference example. Pretty cool stuff!
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
