| New Reply |
Temperature change with altitude |
Share Thread | Thread Tools |
| Apr11-12, 09:20 AM | #1 |
Alright guys, just looking for a point in the right direction for a tutorial question.
GIVEN VALUES: Temperature change with increasing altitude: 0.0065 K/m Temp at sea level: 15ºC Pressure at sea level: 101.5 kPa FIND: Atmospheric pressure at 7500m. So what I've done is found the temperature decrease between sea level and 7500m, so that temperature is 239.4K. And then tried (P1/T1)=(P2/T2), was a bit sceptical over this working.. it didn't. After that tried: ∫(1/P) dP = -∫(g/RT) dz Integrated that, giving: ln(P2/P1) = (-g/RT)(z2-z1) Placed in the values given/calculated, leading to: P = 101500*e^[(-9.81*7500)/(287*288.15)] P = 41.7 kPa ... which is a wee bit off the stated answer of 38.3 kPa. Any ideas? |
| Apr11-12, 10:38 AM | #2 |
Welcome to PF!
In your second integral you should integrate T as a function of z (you have treated it as a constant). Usually one makes the substitution dz = (1/(dT/dz)) dT, where dT/dz is the constant lapse rate so that you get pressure as a function of temperature. Edit: I see now that you have posted outside the homework section of this forum. Please post future homework questions in the homework section to get better responses .
| Apr22-12, 03:06 AM | #3 |
Fantastic, thanks Filip.
| New Reply |
| Thread Tools | |
Similar Threads for: Temperature change with altitude
| Thread | Forum | Replies | ||
| Work While Temperature Change and Heat while pressure and/or temperature change | Classical Physics | 0 | ||
| Which of the following gives the change in altitude of the balloon? | Calculus & Beyond Homework | 5 | ||
| Battery Energy and Altitude Change | Introductory Physics Homework | 1 | ||
| Change in altitude | Introductory Physics Homework | 1 | ||
| How can you calculate density from : altitude temperature and absolute humidity | Mechanical Engineering | 3 | ||
