Continuity of (x^2 + y^2)sin(1/(x^2+y^2)) Derivative at 0
  • Thread starter Thread starter brydustin
    Derivative Limit
brydustin
obviously x^2sin(1/x) isn't continuous in its derivative at zero. But it seems if you take
(x^2 + y^2) sin(1/(x^2+y^2)) and switch to polar coordinates then the derivative is continuous at zero... but that can't be right... can it?
The second function doesn't restrict to the first function on the x-axis, so I'm not sure why you would be surprised their differentiability properties would be different. On the other hand the function
(x^2+y^2) \sin( \frac{1}{\sqrt{x^2+y^2}} )
is the radial extension of your original function to the x-y plane, and when you switch to polar coordinates you get that it is not differentiable at zero (since it's the exact same function once you do that)
Please be more specific. What are your calculations, for instance?
Also, the derivative in polar coordinates aren't that simple. If we have r=f(θ), then f'(θ) isn't necessarily the slope of the line tangent to f at θ.
g'(r,alpha) = (for all alpha) = z2r*sin(1/r*sqrt(z)) - r^2/sqrt(r*z) cos(1/r*sqrt(z)) is what I get. where z = cos^2(alpha) + sin^2(alpha). And the limit should exist as r goes to zero by the squeeze theorem., ... right?
OH, no... I made a mistake. I made a bad substitution as I forgot that r = sqrt(x^2+y^2) and then its really trivial. Funny, that I had this idea but did the transformation wrong, still.
There is the following linear Volterra equation of the second kind $$ y(x)+\int_{0}^{x} K(x-s) y(s)\,{\rm d}s = 1 $$ with kernel $$ K(x-s) = 1 - 4 \sum_{n=1}^{\infty} \dfrac{1}{\lambda_n^2} e^{-\beta \lambda_n^2 (x-s)} $$ where $y(0)=1$, $\beta>0$ and $\lambda_n$ is the $n$-th positive root of the equation $J_0(x)=0$ (here $n$ is a natural number that numbers these positive roots in the order of increasing their values), $J_0(x)$ is the Bessel function of the first kind of zero order. I...
Are there any good visualization tutorials, written or video, that show graphically how separation of variables works? I particularly have the time-independent Schrodinger Equation in mind. There are hundreds of demonstrations out there which essentially distill to copies of one another. However I am trying to visualize in my mind how this process looks graphically - for example plotting t on one axis and x on the other for f(x,t). I have seen other good visual representations of...
