Help with mechanism choice please
  • Thread starter Thread starter Parzibal
    Choice Mechanism
The discussion revolves around selecting an appropriate mechanism for a project requiring a small, lightweight, fast, electric actuator capable of producing a downward force of approximately 15 lbs over a travel distance of about 1.5 cm. The conversation explores various actuator types and their specifications.
  • Exploratory, Technical explanation, Debate/contested, Homework-related
  • One participant expresses the need for a small, lightweight, fast electric actuator that can produce a downward force of about 15 lbs, noting that existing options like electric door lock actuators are insufficient.
  • Another participant suggests a rotary motor powering a screw drive as a potential solution, questioning how to calculate the travel time for a motor/screw combination to cover 1 cm.
  • A third participant recommends exploring industrial surplus stores for electric motors and linear actuators, providing specific websites for further research.
  • A later reply indicates that the original poster found a solenoid to be the suitable mechanism for their needs.
Participants do not reach a consensus on the best mechanism initially, but the discussion evolves with the original poster identifying a solenoid as a solution, suggesting some agreement on its suitability.
The discussion includes varying assumptions about the required specifications and performance of the mechanisms, as well as the original poster's self-identified lack of engineering expertise, which may influence the proposed solutions.
Individuals interested in small-scale electric actuators, hobbyists working on mechanical projects, and those exploring surplus industrial components may find this discussion beneficial.
Parzibal
Hello, I hope you super-geniuses will please take a moment to point a layman in the right direction. If I can get past this sticking point I can complete the rest of this project myself.
I need something small (tennis ball sized or smaller, smaller is better), lightweight, fast, electric, and capable of producing downward force of about 15 lbs, more force is better. The travel distance need only be about 1.5cm. An actuator for an electric door lock for vehicles is close (and cheap,$5) but lacks the force (it produces 10 lbs) and does not seem robust enough.
The force does not necessarily need to go straight down, a small rotary motor with an arm that rotated would work, but I'm guessing the torque on a small motor would not be capable of producing significant force.
I really have no idea even what is available, any input is greatly appreciated, TIA.
...another method might be a rotary motor powering a screw drive. The response needs to be fast tho, perhaps 1/8 sec. My travel distance of 1.5cm was on the long side, I may be able to get away with as little as 1cm. Is there a way to calculate how long it would take for a motor/screw combination to travel 1cm? Again I'm not an engineer but my instinct is that this method would also produce more force.
Thanx for the response. I stumbled around on my own & found that a solenoid is exactly what I was looking for.
  • · Replies 16 ·
