Magnetic Transistors - Better Against Radiation?
South Korean researchers have developed a magnetic transistor switch that could significantly reduce power consumption and enhance durability against radiation. These transistors leverage magnetic states that are less susceptible to damage from cosmic rays, making them ideal for space applications. The potential for magnetic transistors to create robust systems capable of withstanding harsh radiation environments could prevent crashes and glitches in critical missions. Additionally, their resilience may extend to use in nuclear reactors and medical radiation equipment. The technology also holds promise for improving particle detectors, which are exposed to high levels of radiation.
sanman
South Korean researchers have developed a magnetic transistor switch which may save power:
http://www.nature.com/news/magnetic-logic-makes-for-mutable-chips-1.12321
I'm wondering if this could benefit space applications, but on more than just power-saving.
Magnetic states aren't as easily harmed by cosmic rays, thanks to spin majorities. That's why MRAM (magnetic RAM) is good for space applications.
I was then thinking that processors based on magnetic transistor switches could create a more robust system that's much more capable of standing upto the harsh radiation environment of outer space without suffering crashes and glitches that can jeopardize a space mission.
Could magnetic transistors in fact be superior in higher radiation environments like space and perhaps nuclear reactors, and even near medical radiation equipment?
Interesting concept.
Could be useful for particle detectors as well - they receive significant radiation doses (much more than electronics in space).
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
