Solve Infinite Primes with Quadratic Polynomials
The discussion centers on the challenge of finding a quadratic polynomial that generates an infinite number of prime numbers, a concept highlighted by a teacher's assertion that no such polynomial is known. Participants explore the idea of using polynomials like x^2+1 and reference Euclid's proof to consider the implications of assuming only finitely many primes exist. Clarifications are made regarding the nature of quadratic polynomials and their ability to produce primes for natural number inputs. The Bunyakovsky conjecture is mentioned as a relevant framework, with suggestions that certain polynomial forms could yield odd numbers and potentially cover a significant range of primes. The conversation emphasizes the ongoing quest to identify polynomials that might lead to infinite primes.
cragar
My teacher said that, No one knows of any quadratic polynomial that produces an infinite amount of primes. I was thinking could we use a polynomial like
x^2+1 and then do a trick similar to Euclids proof of the infinite amount of primes
and assume their are only finitely many of them, But this probably won't work.
How else could we try to do this.
Mathematics news on Phys.org
What does this statement mean? How does a quadratic polynomial "produce" a prime?
2^2+1=5 that's what I mean, are values for x are the naturals
Okay, just clarifying, are you asking for a quadratic such that there are an infinite number of positive integer inputs for x which produce prime numbers?
a couple things I noticed is polynomials of the form x^2-x+1
will always produce odd numbers and can't be factored so that's a good start.
and the polynomial x^2+x+1 produced the same primes as
x^2-x+1 Maybe we could find a set of polynomials that covered a large portion of the odd numbers and then we would know at least one of these produced an
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
