New Reply
Throwing a Ball...
Share Thread Thread Tools
Feb10-13, 10:30 PM   #1
VU2
Throwing a Ball...
Q1) You throw a ball. Assume that the origin is on the ground, with +y-axis pointing upward. Just after the ball leaves your hand its positon is <.06,1.03,0>m. The average velocity of the ball over the next .7s is <17,4,6>m/s. At time .7s after the ball leaves your hand, what is the height of the ball above the ground.
y=1.03+4(.7)-9.8/2×(.7^2)
y=1.429 is my answer, is this correct? I'm using the average velocity as initial, so i'm not sure if I can assume that or not.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Ants and carnivorous plants conspire for mutualistic feeding
>> Forecast for Titan: Wild weather could be ahead
>> Researchers stitch defects into the world's thinnest semiconductor
Feb10-13, 10:59 PM   #2
Recognitions:
Homework Helper Homework Help
Welcome to PF;
Probably not.
Check it to see if it matters. Depends how accurate your answer needs to be.
You know the acceleration and the average velocity, can you find the y-component of the initial instantaneous velocity.
Note: how is "average velocity" calculated?
Feb11-13, 01:25 AM   #3
VU2
AvgV is calculated by (finalV+initalV)/2=AvgV, can i assume that initial V is 0?
Feb11-13, 01:33 AM   #4
tms
Throwing a Ball...
No, you can't assume that. You can, however, calculate the final velocity in terms of the initial velocity, given the acceleration and the time. That will allow you to get the initial velocity from the average.
Feb11-13, 01:39 AM   #5
VU2
Oh I see, y-final=y-initial + v(avg)*(t). Therefore, y-final=1.03+4(.7)=3.83?
Feb11-13, 01:57 AM   #6
tms
That will work, too, more directly than what I suggested. I don't know what the notation "<17,4,6>" means, so I don't know if your answer is right.
Feb11-13, 02:18 AM   #7
VU2
That is the average velocity vector.
Feb11-13, 02:19 AM   #8
VU2
I'm curious now, how would you compute it your way?
Feb11-13, 02:32 AM   #9
tms
Quote by VU2 View Post
That's what I thought, but I was wondering why the z direction was there, since it isn't mentioned in the rest of the problem.
Feb11-13, 02:33 AM   #10
tms
I explained it above. It is essentially the same, except that it takes a roundabout way to get there (basically deriving the equation you used).
Feb11-13, 02:40 AM   #11
VU2
Oh I see, thanks!
Feb11-13, 06:46 AM   #12
Recognitions:
Average velocity is change in position over change in time:
##\bar{v}=\Delta y/\Delta t = (y_f-y_i)/\Delta t##
... you rearranged that equation to give you the final height given the initial height and the average velocity ... well done.
As an exercise - how would it have been different for the same figures, except the average velocity was timed over 0.1s, but you still want the final height after 0.7s?
Feb14-13, 05:09 PM   #13
VU2
Simon Bridge,
Sorry, I was suppose to get back to you sooner. That's an interesting question. I'm not sure how I would approach it, to be honest.
Feb15-13, 06:19 AM   #14
Recognitions:
Well - in that case you'd have two time periods ot consider: one short one (with a displacement) to establish the initial velocity and another, longer, one to find the answer. Otherwise the approach is identical to the one you used above.
IRL you often measure the speed of something by timing it over a short distance, and then use that information to work out where the thing will end up.
Feb15-13, 12:43 PM   #15
VU2
Simon Bridge,
Yeah that's what I figured too. Thanks for the lesson.
Feb15-13, 09:18 PM   #16
Recognitions:
No worries - have fun :D
New Reply
Thread Tools
Similar Threads for: Throwing a Ball...
Thread Forum Replies
Throwing ball Introductory Physics Homework 7
Throwing a ball into the air... Introductory Physics Homework 3
Throwing a ball Introductory Physics Homework 8
throwing a ball Introductory Physics Homework 3
