Current in the primary coil of transformers used in rectifier circuits
The current in the primary coil of a transformer in a full wave rectifier can be analyzed using the relationship V(s)I(s) = V(p)I(p), but the applicability depends on whether peak or RMS values are needed. For peak current calculations, the peak voltage should be used, while RMS values are appropriate for other calculations. It's important to note that the average current over one complete cycle of a sine wave is mathematically zero. This means that when considering average values, the sine wave nature of the current must be accounted for. Understanding these distinctions is crucial for accurate transformer current analysis in rectifier circuits.
egnrbyaccident
Can anyone please clarify if the current in the primary coil of the transformer follows V(s)I(s)=V(p)I(p) when i am trying to figure out the peak, surge and average current through the primary coil of a transformer in a full wave rectifier.
Also, if it does, do I just use the peak voltage or the rms value?
It does and it does not . That depends on what are u trying to calculate.
You can use this relationship to calculate the "peak" voltage / current and R.M.S value , depending on what you need.
One more thing, as long as the average current or voltage is concerned it would mathematically be zero since the Current is a sine wave function . The mean value of such a current over one complete cycle would be zero .
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
