Conservation of Energy: Comparison between momentum & magnetic fields
Momentum and magnetic fields are both vector quantities, with momentum conserved in head-on collisions where kinetic energy transforms into other forms. When identical strength magnetic fields meet, a gauss meter may read zero in the direction of the field, but this does not imply energy conservation; instead, the total magnetic energy increases due to the forces required to bring the magnets together. The interaction of magnetic fields results in both cancellation and reinforcement of energy density, leading to complex force dynamics. In electromagnetic interactions, regions of reduced energy density can exist alongside areas of increased energy density, affecting the overall force experienced. Understanding these interactions requires considering the entire field volume rather than isolated points.
magnetics
Momentum and magnetic fields are both vector quantities.
If two bodies with the precise mass and speed collide head on (θ = 0), then momentum is conserved (they come to a complete stop) and energy is conserved (the kinetic energy is changed to other forms).
What then happens in the case of two identical strength magnetic fields that meet head on? A gauss meter placed precisely in between them would read zero if measured in the same direction of the field. Is the energy conserved simply by changing direction?
This is an oxymoron as energy is not a vector quantity.
Thank you.
When magnetic fields overlap and interact there is a change in the energy density of the field. This is what gives rise to forces when magnets are brought together, from F=dU/dl. Although the gauss meter reads zero there is actually an increase in the total magnetic energy in the system. This magnetic energy comes from the forces needed to push the magnets together.
Thank you pumila,
I can see how forcing the magnets together might increase the total magnetic energy in the system. But I'm not sure about the gauss reading.
There may be a zero gauss reading in the direction of the local field vector, but wouldn't the field have been deflected in a perpendicular direction so that the magnitude of the vector does not change, but only the direction?
Thanks,
You have to look at the whole field interaction volume to get the total effect of the field interaction in electromagnetics, but individual points may be quite different to the sum effect. For example, if you look at two electrons near each other, then at the midpoint of the line joining them the energy density drops to zero as the fields exactly cancel each other out. For two electrons, there is a small region of electrostatic energy density reduction - the sphere whose diameter is the line joining the centres of the electrons - in the middle of a much larger and more significant region of increased energy density. Hence in the interaction between two electrons there is a small region of attractive forces (associated with the central reduced energy-density zone) that is entirely swamped by the repulsive forces.
Do not think of the field lines as being distorted as the magnets come together. Rather, look at the composite field vector. If we imagine one of your magnets on top of the other, then in the horizontal plane that defines the midpoint between your magnets, all vertical field vector components exactly cancel out (vector addition). All that is left in that plane is the horizontal components, and at the centre of the plane there will be none.
Essentially, in most static electromagnetic field interactions there are regions of both types - that is, where there is some cancellation of the electrostatic field (leading to a reduction in energy density and hence attractive forces) as well as regions where there is re-inforcement.
It is relatively easy to perform the maths for electrons (which have simple polar fields), but I have not personally done it for magnets, since the geometry is highly variable. Nevertheless simple observation indicates a region of reduced energy density in the region between the magnets, swamped by a much larger region of repulsion elsewhere.
P.S.
If you want to look at the interaction between two electrons in more detail, start with the potential energy density function
dU/ds = εE_{1}.E_{2}
where epsilon times the dot product of the electric field vector from one electron at a point and that from the other at the same point, is the potential energy density at that point.
Integrating this function over all space gives the potential energy
U=q^{2}/4∏εr
and differentiating this with respect to separation gives the force
F=-q^{2}/4∏εr^{2}
You can perform a similar integration for the magnetic potential energy between two magnets, but you have multiple geometries to choose from.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
