Charge Transfer and Force Dynamics in an Electromagnetic System
  • Thread starter Thread starter Berzurker
    Electromagnetism
In the discussed theoretical scenario, a positively charged ball at the center of a negatively charged circle interacts with four outer positively charged balls. Transforming some charge from the center ball to the circle alters the charge distribution, affecting the forces at play. When the center ball has more charge, the outer balls experience greater repulsion, pushing them away. Conversely, when the center ball loses charge and the circle gains negative charge, the attraction increases, pulling the outer balls closer. The dynamics of this system illustrate how changing charge affects electromagnetic forces and interactions.
Berzurker
Hey guys, it's been a long time since I've taken physics and I was hoping for some help on this theoretical situation.
Ok, let's say you have a positively charged ball placed in the middle of a negatively charged circle. Outside of the circle are 4 positively charged balls, one to the north, east, west, and south.
What happens if I could magically transform some of the charge from the positive center ball into negative charge and transfer it to the negatively charged circle?
The dynamic I'm trying to set up is when the positive center ball has more charge, the 4 positive balls are pushed further away from the circle, and when the center ball looses charge the negative circle gains charge and pulls the 4 balls closer to the circle/the center ball. I'm just not positive how the forces will act since I am changing the absolute value of charge equivalently for both the center ball and the negative circle at a given time.
You would violate the laws of physics, and change the charge distributions. What do you mean with "what happens"? If you release the outer balls and the charge of the circle gives more attraction than the repulsion between the balls, they will be attracted towards the circle.
Both changes increase the force towards the center.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
