the_emi_guy said:
Generally when I see noise levels in the millivolts or hundreds of microvolts caused by thermal noise I am dealing with both wide bandwidth and high gain. The unity gain ADC front end amp couldn't possibly have poor enough thermal noise figure to add hundreds of microvolts of noise could it?
Consider the AD10200 (Analog Devices, 12-bit, first one on their list). This is a 250MHz bandwidth part with 50 ohm input.
Theoretical SNR due to 12-bit quantization (SQNR) in dB below full scale is 74dBFS or 0.14mVrms of noise.
Advertized SNR = 67dBFS = 0.32mVrms.
Thus there is 0.18mVrms of noise in excess of quantization noise, or -62dBm.
If we assume that this is thermal noise, and that the device has 250MHz bandwidth, than this is
-86dBm/1Hz. This is 88dB above the thermal noise floor of -174dBm/Hz.
In other words this part's analog front end would have to have a noise figure of 88dB against thermal noise even though it has no gain! Even a crappy unity gain voltage feedback OP amp with large resistor values would have noise figure below 50dB.
I suspect that the excess noise in the SNR spec is due to other impairments such as clock jitter.
I think knowing a little bit of what is under the hood of a Nyquist ADC could really help you make sense of it. First off, the limitation is not jitter in these ADCs. Most high-performance part have an on-chip PLL that cleans the jitter from the reference clock or it specifies a clean clock signal as part of the ADC support circuits. The noise issue is due ti the front-end sampling network of the ADC.
Basically, ADCs like the part you mentioned (AD10200) use a pipeline architecture, meaning they comprise several identical (or similar) conversion stages. Each stage uses a two-phase non-overlapping clock and a switched-capacitor sampling network. In the first phase, the input is sampled on some capacitors, and in the second phase, this held input is amplified and sampled by the next stage. The issue is with these capacitors.
When you sample a voltage onto a capacitor, there is a thermal noise associated with the sampling with a variance of kT/C where C is the value of the sampling capacitor. It is independent of the series resistance because while the resistor provides the noise (ideal caps are noiseless) the R in the denominator cancels the R in the numerator because the R both generates noise and sets the bandwidth.
Therefore, the noise will be limited by kT/C unless you make the capacitors big enough. However, if you make your capacitors larger it will take more power for your stages to settle in a given time.
So, Nyquist ADC designs are a compromise. They could theoretically be made quantization-noise limited but the market generally doesn't pay for that, so the noise is set at an acceptable level which reduces power consumption and cost. Fitness to purpose.
To get a bit more quantitative, notice that since the noise variance (or power) on a capacitor is kT/C, the rms voltage noise is sq-root(kT/C). That means to reduce the noise voltage by X, you need to increase your capacitor size by X^2. To first order, the power is proportional to the capacitance so the power also increases by X^2.
Therefore, for the AD10200 to reduce its input referred noise to 14 mVrms would require a 4X increase in power consumption! Even then the overall noise wouldn't be 74 dB. Since thermal noise and quantization noise add in quadrature (assuming the input is "busy enough") if the quantization noise were equal to the thermal noise, then the SNR would be degraded by 3 dB to give 71 dB. OUCH!
You can see why commercial ADCs have better linearity than their noise specs.
Also, in case you're interested, this is an IF sampler meaning it is intended for use to sample the Intermediate Frequency of a superhet receiver (obviously the ADC is general purpose, but that's where the spec comes from). In that case, the desired channel is narrowband and the SNR can be greatly improved through the use of a sharp digital bandpass filter downstream of the ADC.
The linearity is key, though, because you don't want intermodulation distortion blocking channels.
So for an RF receiver, typically, linearity is paramount and noise performance is relaxed.
