Arc length of a regular parametrized curve
The arc length of a regular parametrized curve is defined as s(t) = ∫ from t_0 to t of |α'(t)| dt, where |α'(t)| represents the magnitude of the derivative vector. The derivative of arc length with respect to the parameter t is given by ds/dt = |α'(t)|, indicating that if the parameter t itself represents arc length, then ds/dt equals 1. This implies that when |α'(t)| = 1, the arc length simplifies to s = t - t_0. Clarification is needed if there is confusion regarding the conditions under which ds/dt equals 1. Understanding these relationships is crucial for working with parametrized curves in three-dimensional space.
tuggler
Given t\in Ithe arc length of a regular parametrized curve \alpha : I \to \mathbb{R}^3 from the point t_0 is by definition s(t) = \int^t_{t_0}|\alpha'(t)|dt where |\alpha'(t)| = \sqrt{(x'(t))^2+(y'(t))^2+(z'(t))^2} is the length of the vector \alpha'(t). Since \alpha'(t) \ne 0 the arc length s is a differentiable function of and ds/dt = |\alpha'(t)|.
This is where I get confused.
It can happen that the parameter tis already the arc length measured from some point. In this case, ds/dt = 1 =|\alpha&#039;(t)|[/tex]. Conversely, if |\alpha&amp;#039;(t)| = 1 then s = \int_{t_0}^t dt = t - t_0.<br /> <br /> How did they get that it equals 1? I am not sure what they are saying?
Mathematics news on Phys.org
Opps, I am in the wrong thread. How can I delete this?
tuggler said:
Given t\in Ithe arc length of a regular parametrized curve \alpha : I \to \mathbb{R}^3 from the point t_0 is by definition s(t) = \int^t_{t_0}|\alpha&#039;(t)|dt where |\alpha&#039;(t)| = \sqrt{(x&#039;(t))^2+(y&#039;(t))^2+(z&#039;(t))^2} is the length of the vector \alpha&#039;(t). Since \alpha&#039;(t) \ne 0 the arc length s is a differentiable function of and ds/dt = |\alpha&#039;(t)|.
<br /> <br /> If t is arc length (that is: s = t), then ds/dt = 1. If this doesn&#039;t answer your question you need to elaborate.
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagorus'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
