Shear Failure of Adhered Polystyrene (to Aluminum)
The discussion focuses on the shear failure of polystyrene adhered to aluminum in a composite metal panel assembly due to thermal expansion differences. The original calculations suggested a dangerously low allowable temperature gradient of 2.39°C before shear failure occurs. It was pointed out that the approach of calculating thermal stress based on restricted expansion was flawed, as it did not account for the differing thermal strains of the materials. Instead, the analysis should compare the thermal strain differences between the aluminum and foam to the elastic strain at which the foam fails. Additional resources were shared to aid in refining the calculations and understanding the nonlinear thermal expansion behavior of the foam.
banfillb
Hi All,
So here's the problem. A project I am working on has a composite metal panel assembly, which a previous engineer designed. The metal panels are simply glued to the polystyrene (styrofoam sm). The problem is that the previous engineer did not consider the difference in thermal expansion between the foam and the aluminum, and the foam has begun to fail in shear, and detach from the metal panels.
I'm putting together a report basically laying out the problem, and what I want to find is a temperature gradient which is "allowable" before the styrofoam will shear.
Basically what I have done is set the thermal stress due to restricting thermal expansion (σ=EαdT) equal to the shear strength of the styrofoam (452kPa) and solved for the dT...which ended up coming out to 2.39degC...which seems extremely low to me.
Any suggestions on where I have gone wrong? The only thing I can think of is that I can't directly use the thermal stress due to restriction of thermal expansion directly as a shear force...not sure.
Thanks,
Thermal stress (σ) created by thermal expansion resistance will be calculated using the following formula:
σ=E∙α∙dT
Where: σ= Thermal Stress (kPa)
E= Youngs Modulus (GPa)
α= Thermal Expansion Coefficient (m/(m℃))
dT= Temperature Differential (℃)
The thermal stress (σ) value will then be compared to the shear strength of the Styrofoam SM. If σ>F_v, then shear failure will occur.
The thermal stress (σ) will then be set to the shear strength (F_v) of Styrofoam SM in order to find the minimum temperature differential which shearing in the Styrofoam SM will occur.
CALCULATIONS:
σ=E∙α∙dT
σ=(3x10^6 kn/m^2 )(63x10^(-6) m/(m℃))(100℃)
σ=18,900 kPa
σ>F_v
∴, shearing WILL occur
452kPa=(3x10^6 kn/m^2 )(63x10^(-6) m/(m℃))∙dT
dT=2.39℃
∴, shearing will occur at any temperature differential greater than 2.39℃
You seem to have calculated the stress in the steel assuming it cannot expand, and then applied all that stress across the interface to the styrofoam.
That is the wrong thing to do (and your temperature difference is obviously much too small).
It would make more sense to find the difference in thermal strain between the metal and the foam (caused by the different expansion coefficients) and compare that with the elastic strain at which the foam will fail.
But the measured data here http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20070008201_2007006834.pdf seems to imply the thermal expansion of the foam is very nonlinear (and large, and irreversible) above about 100 C.
You can probably simplify the analysis in that PDF, since I would guess Young's modulus for the foam is negligible compared with aluminum.
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
