Binomial expansion of a function with x raised to a power
To binomial expand the function 1/(1-x²), the series can be expressed as 1 + (-1)(-x²) + (-1)(-2)(-x²)²/2! + (-1)(-2)(-3)(-x²)³/3! and so on. This expansion is correct, and the coefficients follow a pattern based on factorials and alternating signs. Understanding this pattern will aid in expanding similar functions like ∏(1/(1-x^i)) for i up to 6. The discussion emphasizes recognizing the coefficients in the expansion and their relationship to the binomial series. Mastering this technique will facilitate further calculations involving binomial expansions.
Dixanadu
Hey guys.
So I need to know how to Binomial expand the following function
\frac{1}{(1-x^{2})}.
I need this because I have to work out \prod^{∞}_{i=1}\frac{1}{(1-x^{i})} for i up to 6. But I have to do it with Binomial expansion. If i can learn how to do \frac{1}{(1-x^{2})} then the rest of the powers should be the same.
I was under the impression that \frac{1}{(1-x^{2})} can be binomial expanded as
1+(-1)(-x^{2})+(-1)(-2)\frac{(-x^{2})^{2}}{2!}+(-1)(-2)(-3)\frac{(-x^{2})^{3}}{3!}+...
Is that correct?
Thanks guys!
Mathematics news on Phys.org
This is correct, and you probably want to observe that
(-1)/1! = -1
(-1)(-2)/2! = 1
(-1)(-2)(-3)/3! = -1
and you can probably guess the pattern as you continue.
Wait, wait- don't tell me. I'm still working on it!
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
