Experiment with Earth magnetic fields abnormal
The discussion revolves around an experiment involving compasses that exhibit unusual spinning behavior when moved vertically in a specific location suspected of bio-electromagnetic weapons testing. The compasses consistently point to magnetic north when stationary but spin counterclockwise when moved down and clockwise when moved up. Participants suggest that local magnetic fields or environmental factors may be influencing the results, while others express skepticism about the involvement of bio-electromagnetic weapons. The experiment has been conducted in various settings, away from metallic objects, to rule out interference. The phenomenon remains unexplained, prompting requests for further insights or theories.
beatfrequency
I have an enigmatic problem that I cannot explain.
I have on video the results of this experiment at particular location where I believe bio-electromagnetic weapons testing is occurring.
Does anyone have theories of why the following occurs?
I have several sized physical compasses that the experiment all works with so it is not a result of friction or anomalies of the compasses.
When the compass is in steady state it points to magnetic north, but when it is moved a couple feet relatively quickly straight down it spins several times counter clockwise while going down the body. It stops again at magnetic north. Then when it is brought up a couple feet quickly it spins in a clockwise rotation. This is repeated continuously.
Can anyone shed some light on this phenomenon?
Thanks in advance.
Maybe local magnetic fields. We do not know your method of moving the compasses or the near environment.
try a control test somewhere you think the magnetic fields are ordinary at least once
i think its just a normal occurrence and i doubt any "bio-electromagnetic weapons" would cause such a thing
The experiment has been done in a field, in homes 20 feet from any metallic object including on the subject. The compasses were lifted by a human being parallel to the plane of the ground up and down about 1.5 feet.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
