Some numbers with wind turbines
The discussion focuses on the efficiency of wind turbines, specifically a GE Wind Energy model with a rotor swept area of 4657 m^2 and a power output of 1.5MW at a wind speed of 11.5 m/s. The theoretical maximum power output calculated is 4.25MW, indicating that the turbine extracts approximately 35% of the kinetic energy from the airflow, which is considered reasonable. The high efficiency is attributed to the turbine's high aspect ratio airfoil blades that move at high speeds, affecting a larger volume of air. Betz's Law is referenced as a theoretical framework for understanding the maximum energy extraction possible from wind. The discussion confirms the validity of the calculations regarding the turbine's performance and efficiency.
jostpuur
http://en.wikipedia.org/wiki/GE_Wind_Energy
The rotor swept area is 4657 m^2, and wind speed is 11.5 m/s. Produced power 1.5MW.
I assumed that the air density is 1.2kg/m^3, and computed, that the theoretical upper limit for produced power would be 4.25MW. This was obtained by computing the kinetic energy in an air mass of cylinder shape.
So the turbine extracts 35% of the kinetic energy of the air flow? Is that a reasonable percentage? Looks quite large to me. How could the three blades with relatively small surface area extract this much?
That's absolutely a reasonable amount, and the way the blades can manage it is because the blades are high aspect ratio airfoils moving at fairly high speeds, so they affect a fairly large region of air around them. The turbines look like they spin slowly because of their large size, but if you work out the blade tip speed, it can be well in excess of a hundred miles per hour. If you're interested in the theoretical limits, you might like reading about Betz's Law, which describes the theoretical maximum energy you can extract with a wind turbine in a free stream.
Likes 1 person
I could tell that my "theoretical upper limit" wasn't really the best (lowest) possible upper limit, but I didn't know about the Betz's law, so thanks for the link.
I was suspecting that there is something peculiar about the relatively small blades moving with high speeds, but I wasn't sure if my numbers were right, and I wanted confirmation.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
